  1. I've made this SVCD that looks and plays perfect, but I've got a question. If I want to skip around in the movie I have to fast forward or rewind, it's like using a tape. I would like to split it up into chapters so that I can skip around to different scenes on the CD. Could somebody point me to a tutorial or describe the process involved in splitting up a SVCD into chapters?
    Thanks ahead of time for any help.
    Aug 2001
    Västerås, Sweden
    Take a look in the authoring howtos.
    http://www.vcdhelp.com/burnmpg.htm
    Well, I am the slime from your video.
    Oozin' along on your livin'room floor.
  3. So different chapters are simply different files? I just have to split the MPEG up? Will it cause any pauses between chapters? You can't create chapter indexes into a single MPEG file or anything like that?
  4. NO!!!! Do not spilt the MPEG up. You can't create 'true chaptes like a DVD' on a x(S)VCD. But you can create entry points that work just like chapters. If you spilt the MPEG up you'll make multiple tracks, but there will be a pause between each track when the MPEG plays. However, using entry points there will be no pause, and you'll still be able to use the << >>, remote keypad, etc. to navigate your disc (arrow keys won't work).
    1) If you've already burned the disc you need to get the MPEG back on your HD. If it's a VCD use VCDGear to convert the dat file -> MPEG. If SVCD just copy MPG back to HD.
    2) Use VCDImager to create entry points. VCDImager is a command line program that uses the XML file structure. Many people find it easier to use a GUI for it. VCDEasy and TSCV are the most popular (you can find guides to both to the left under Author).
    Both VCDEasy and TSCV come bundled w/ CDRDAO a freeware cd burning program that can burn the bin/cue files generated by VCDImager.
  5. I am creating chapters in Iauthor .. Works good ..
  6. Forgot about Iauthor, it's like next to impossible to find and only sold in china (I'm not connected to the priate sites like I use to be). VCDImager is free and easy to find, but there are a lot of different ways to do this. I just suggested one. Luck...
