VHS is suppose to be 240 vertical resolution? so when I capture VHS at 480 resolution, what type of filter is virtualdub using to stretch the image? and which resize filter is best? bilinear? bicubic? or some other? thanks for any help
VHS consists of 480 discreet horizontal scanlines. You should capture at that (typically 720x480 or 352x480). Otherwize you'll only get half the vertical and temporal resolution. Unless you have special needs of course.
A further problem you will have is that the video will be interlaced. You must be careful when resizing interlaced video. You should avoid resizing vertically if at all possible.
When downsizing in VirtaulDub Lanczos3 is almost always best.
When upsizing Bicubic or Lanczos3 are best (nearly identical, bicubic is faster). -
Just to add, NTSC Video is 480 vertical lines. PAL/SECAM video is 576 Vertical Lines.
The Lanczos3 benefits on resizing, mostly shows when you do some shaperning on you source.
Resizing(Frame Size) w/ VIRTUALDUB - PLEASE HELP!!!
By MDrumm in forum EditingReplies: 8Last Post: 17th Jan 2011, 03:12 -
Resolution Resizing & Using Filters
By OllyPomm in forum Video ConversionReplies: 9Last Post: 25th Nov 2009, 23:21 -
Resizing images in Virtualdub
By mjf314 in forum EditingReplies: 4Last Post: 30th Sep 2009, 00:05 -
[Solved] Question about MPlayer filters in FFDShow and Mencoder filters
By BlooderButcher in forum Video ConversionReplies: 4Last Post: 24th Nov 2008, 12:32 -
virtualdub filters
By demonwarrior in forum EditingReplies: 5Last Post: 9th Jun 2007, 06:27
