I bought this DVD player from Costco last month, and from the start I noticed some dvd's would play fine and others would play funny (example: the picture would be fine in the middle but anything on either side looked stretched out and fat looking) so I looked on Philips site and saw there was a firmware upgrade, I did the upgrade and tada it worked....but only until I turned off the DVD player, then it's like my player forgets everything, and it goes back to the way it was...anyone else having this problem?? cause Philips wants me to send it to them to do an exchange and wait 30 days to get it back....
I would first take it back to Costco and get a replacement. Then see if the new one has the same issue. You might just have a bad unit....
Are you using a wide screen TV? The "fine in the middle but anything on either side looked stretched out and fat looking" is one of the stretch modes typical of HDTVs. Meaning all you have to do is change the stretch setting on your HDTV.
Question about AVI files and DVD player Philips DVP 5982
By jtrinc in forum Software PlayingReplies: 1Last Post: 24th Nov 2008, 20:23 -
philips 5982 divx usb problems
By fredwilson in forum Newbie / General discussionsReplies: 7Last Post: 15th Feb 2008, 23:42 -
Philips DVP 5982 Time Search Question
By TufrThanu in forum DVD & Blu-ray PlayersReplies: 5Last Post: 18th Oct 2007, 16:05 -
Philips DVP 5982 Audio/Video Mismatch
By MySickStoryXXX in forum DVD & Blu-ray PlayersReplies: 9Last Post: 15th Oct 2007, 10:44 -
Phillips DVP 5982 Subtitles do not work
By shawnh in forum DVD & Blu-ray PlayersReplies: 3Last Post: 14th Jul 2007, 09:37
