  1. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    I have been trying to encode using mencoder via gui's and commandline and am not having any luck. It doesn't matter how I try to encode (gui or commandline) I get an error.
    error
    The Instruction at "0x01b897a8" referenced memory at "0x01cb3e60".  The memory could not be "read"
    I have tried mediacoder, mewig, mcbatch, smsg. No luck.
    Commandline used.
    for %%a in ("*.avs") do "C:\mplayer2007.08.19.Athlon-XP\mencoder.exe" "%%a" -o "E:\Mencoder Output\%%a_pass1.m2v" -ovc lavc -lavcopts vcodec=mpeg2video:vpass=1:vrc_maxrate=9000:vrc_buf_size=1835:keyint=15:vmax_b_frames=2:brd_scale=0:dc=8:psnr:turbo:aspect=16/9:vqscale=3:vb_strategy=0:vqmin=1:vqmax=31:vb_qfactor=1.25:vb_qoffset=0:lmin=0.01:lmax=31.00:vi_qfactor=0.10:vi_qoffset=0:vqcomp=0.75:vqblur=0:mbd=0:mbcmp=256:precmp=256:cmp=256:subcmp=256:me_range=128:preme=2:vme=4:dia=3:predia=3:sc_threshold=0:sc_factor=1:bidir_refine=0 -of rawvideo -ffourcc MPG2 -nosound
    for %%a in ("*.avs") do "C:\mplayer2007.08.19.Athlon-XP\mencoder.exe" "%%a" -o "E:\Mencoder Output\%%a_pass2.m2v" -ovc lavc -lavcopts vcodec=mpeg2video:vpass=2:vbitrate=1800:vrc_maxrate=9000:vrc_buf_size=1835:keyint=15:vmax_b_frames=2:brd_scale=0:dc=8:psnr:aspect=16/9:vqmin=1:vqmax=31:vb_qfactor=1.25:vb_qoffset=0:lmin=0.01:lmax=31.00:vi_qfactor=0.10:vi_qoffset=0:vqcomp=0.75:vqblur=0:mbd=0:mbcmp=256:precmp=256:cmp=256:subcmp=256:me_range=128:preme=2:vme=4:dia=3:predia=3:sc_threshold=0:sc_factor=1:bidir_refine=0 -of rawvideo -ffourcc MPG2 -nosound
    It gets to 99% of the first pass of the first file then errors out. I've tried searching but haven't found any thing relavant. I'm using celtic druid's build "mplayer2007.08.19.Athlon-XP" but have had the same error using other builds.
    Donadagohvi (Cherokee for "Until we meet again")
  2. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    I'm just curious about encoding with mencoder. While it was working It hit 39fps which is faster than HC on my ancient system. If I can't get it working it's no real big deal. HC serves my needs anyway.
    Dec 2004
    Triptonia
    The problem with memory errors is they can be caused by just about anything.
    not the easiest thing to track down.
    Have you tried this one?:
    http://oss.netfarm.it/mplayer-win32.php
    That would be my first suggestion.
    Yeah sure!
    On the first pass.
    Try halving that for the second pass.
    Mencoder needs to be fine tuned to get the best out of it. the heavier the options, the slower it gets.
    In any case it's not faster than HC, not when you factor quality.
    also worth mentioning an amount of junk in the commandline, where you're just stating default values...
    vqmax=31:lmax=31.00:mbd=0:vme=4c_threshold=0c_factor=1:bidir_refine=0
    1800kbps?
    i suppose an xvid/avi.
    If you can't get it rolling and are still curious, upload a sample and i'll encode with your commandline to satisfy the curiosity.
    I'm sure it does more.
    gl
  4. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    Thanks for the reply 45tripp. Yeah it's xvid files (not the greatest quality to begin with). I've decided that getting mencoder working is going to be more trouble than it's worth. I'll stick with HC. The quality it puts out is great and the time really isn't a factor. If I have long encodes I just run them at night. I was just in the mood to test and try new encoders...
