I recently purchased a new computer with Vista on and a DVD burner.
Previously I used to download AVI's trailers etc on my laptop burn the to CD and watch them on my DVD Divx player.
In vista I am downloading the AVI then clicking burn inserting a CD type that I used to use on my laptop and burning the AVI but now they simply won't play on my DivX player, say unable to read disk.
Any ideas? Is this the Vista burn program? Do I need another utility?
I guess you are making a multisession cd with Vistas burning tool and it wont work on many dvd players. Check if you can change any such settings in the vista burning tool. But I would burn with a different tool, just be sure to select a no multisession cd and that you want to close the cd when you burn.
See http://windowshelp.microsoft.com/Windows/en-US/help/2af64e60-60aa-4d79-ab6c-3a5db5806cbe1033.mspx , you should not use any live file system format.
I don't know if that's Vista or your AVI causing the problem. Most AVIs off the net are player ready, so I would try a different burning program. ImgBurn can do data files by using 'Build' mode. Other CD/DVD burning programs here, but I don't know which ones are compatible with Vista: https://www.videohelp.com/tools/sections/burn
And you might drop the file into Gspot 2.70 and see what formats it's using.
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 08:28 -
DVD player won´t play converted .avi
By dexter30 in forum Video ConversionReplies: 4Last Post: 10th Dec 2010, 16:59 -
[SOLVED]Audio won't play for an AVI file in my standalone DivX/XviD player!
By =CrAzYG33K= in forum AudioReplies: 4Last Post: 13th Oct 2008, 09:32 -
Would this DVD player play AVI files burnt onto a blank DVD/CD?
By jane2 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 20th Apr 2008, 20:38 -
Neuview player won't play .AVI videos
By sic in forum Software PlayingReplies: 9Last Post: 16th Oct 2007, 14:01
