Here is my issue
when i went on vacation I accidently put a DVD-ROM mini disk into my camcorder
As my vacation continued other disks were DVD-R
I also used a second camcorder that recorded on a SD Memory card
Now,back home i want to put ALL of the video onto one or two full size DVDs for my friends to watch
I quickly found out that the VRO File from the DVD ROM and the VOB file from the DVD-Rs wont drag into windows movie maker OR Nero
I WAS sucessfull at copying everything to my Laptop though
Hence i need something that will convert VRO and VOB to another Format
2 people suggested Super C from erightsoft.............i went to thier webpage and was completely baffled about what link to click on to download what i needed
I have a MacIntosh PC also but when i put a USB between the camcorder and Mac............it sees the disk insde the camcorder as a .exe file and wont do anything with it.
I am hoping someone here can post a link and a few instructions
I also hace a San-Disk V-Mate,if all else fails could i drag the files onto a 4gb Memory card and then play it back in real time into a VCR and record it on tape OR will the V mate Not recognize the VRO and VOB files?
I ask this because i dont want to invest the $100 into a 4gb card if it wont work
thanks in advance
You can use tmpgenc dvd author or ulead dvd workshop or ulead dvd moviefactory to import the vobs and vros directly(select to import dvd and choose the folder with the vob,vros) and then edit and burn.
If you still need to dl Super
https://www.videohelp.com/tools/SUPER_1
use the mirror link....." Who needs Google, my wife knows everything" -
Using a MacIntel Pro running OSX I tried unsuccessfully to open a mini-dvd with a .vro file. I'd like to know how kaapo did it.
A .vro is an MPEG file, so you're not really converting anything.
Yes I am aware of mpeg streamclip and I have used it successfully. My added twist has to do with the minidvd upon which my Canon DC230 recorded the .vro file. I can put the minidvd in an external dvd drive. Streamclip sees the file, but within 5 seconds it crashes and gives me the message that Streamclip has closed unexpectedly, with the option of reporting the bug to Apple. Unfortunately, though I have emailed the developer about the issue, I have received no response. On a pc I was able to copy the .vro file from the original minidvd and burn it to a new regular sized dvd. On my mac, Streamclip saw that file and opened it without issue. This is a cumbersome work-around and defeats my having switched to mac. It might just be the brand of the minidvd, but I doubt it. Any help here? P.S. that is why I was interested in Avidemux, but I think Avidemux will not open a .vro file.
Best Way to Convert and Deinterlace VRO
By Spiralagnus in forum Video ConversionReplies: 8Last Post: 4th Dec 2010, 19:29 -
MPEG Streamclip VRO Files
By bz186 in forum EditingReplies: 0Last Post: 10th Sep 2009, 16:06 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
Suddenly can't convert VRO to DVD video
By johnsees in forum Newbie / General discussionsReplies: 1Last Post: 2nd Aug 2008, 00:30 -
Need to convert VRO to .avi and/or MP4 using a Macintosh computer
By MacPCConsultants in forum Video ConversionReplies: 0Last Post: 17th Mar 2008, 21:09
