Hi I am working on a project in Dvd-lab Pro 2.3 I have a link from the root menu to my chapter selection menu (which consists of 4 menu pages). Is there any way for me to keep the audio active (keep it playing) when the user browses through my chapter selection menu pages instead of starting from the begining of the audio track on each menu page?
Nope...that would be against the DVD spec. The laser must refocus from menu to menu.
Subtitle Workshop is probably worth a look. I haven't had to do this, so I can't say for sure, but it can do pretty much anything else so I would be surprised if it didn't.
Read my blog here.
What is a PAL format subtitle ??
When i have converted pal dvd's to ntsc i've just ripped and used the same subtitle file...
as long as you don't change the length of the video there should be no problems with the timing. -
if you don't change the length or timing of the vid why would it be ??
I've done it alot and never had a problem.....
same length/time + same length/time = same length/time......
Edit:
Okay, i see what you are saying, taking the original subs from an original PAL dvd and using them for an original NTSC dvd... but who does that
Usually the originals have sub's 8)
but he was not real specific about it...
i just assumed he was doing a pal to ntsc dvd conversion.
Need some Menu help from a DVD-lab PRO master
By jeanpave in forum Authoring (DVD)Replies: 13Last Post: 4th May 2010, 16:03 -
DVD Lab Pro menu help
By stantheman1976 in forum Authoring (DVD)Replies: 12Last Post: 27th Jan 2009, 18:27 -
Audio Problem with VMG menu in DVD Lab Pro
By SCDVD in forum Authoring (DVD)Replies: 5Last Post: 22nd Apr 2008, 23:15 -
Motion Menu on dvd lab pro 2
By djakaburo in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2008, 13:03 -
DVD Lab Pro Menu Troubles
By Freestyler223 in forum Authoring (DVD)Replies: 5Last Post: 22nd Dec 2007, 00:30
Thanks guys for your assistance.
