can anyone tell me why i cannot hear sound on a movie I have here is a gspot snap below
Results 1 to 10 of 10
No sound on your computer or standalone dvd player? Mpeg audio might not work on some standalone dvd players or you might have to change audio settings if you output to a audio receiver.
Your PC should definitely be able to play this with sound. However as Baldrick states, some weird standalone DVD player might have problems with MPEG audio. They aren't supposed to have problems with it as the PAL DVD standard allows for MPEG audio and Gspot shows that you have a PAL DVD, but some manufacturers cut corners and for all we know one of them might have decided that "nobody uses MPEG audio any more, so let's drop support for it because no one will notice."
Thank you for including the Gspot snapshot. That was very helpful for you to do that. Usually we get posts like "I can't hear sound on my DVD. Why?" with no more information of any kind and we can't even begin to diagnose the problem. We do need to know if the sound issue is on your PC or a standalone DVD player. It shouldn't be on your PC though, but if it is, try downloading and installing the VLC Media Player. Perhaps the problem is with your playback software and if so, VLC should work fine for you. -
VLC Media Player! And just don't play the vob files, open/select the folder with the vob,ifo files and play.
Or maybe is the soundtrack silent... -
It makes perfect sense. Use "Open folder" (or directory - don't know what it says in the English version) and point it to the VIDEO_TS folder containing your VOBs, IFOs and BUPs.Originally Posted by natty
/Mats -
yes i can see what you mean now, but I still dont have any audio on movie this was my main ? in 1st place video plays ok but still no audio, and I just cannot see whats wrong now, as all my other movies play fine video and audio.
Perhaps there is no sound? Even if there is an audio stream, it could be all silence. Like when WinAVI converts an AVI it can't decode the audio from; It will happily convert it anyway, and put a silent audio track in.
/Mats
sound commentary in movie
By terblo in forum Newbie / General discussionsReplies: 0Last Post: 9th Dec 2009, 17:34 -
Movie sound Ripper..
By ranchhand in forum AudioReplies: 9Last Post: 1st Jan 2009, 15:06 -
no sound on my avi movie
By hardtime in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 23:28 -
Main Movie has no sound
By Keesfan in forum DVD RippingReplies: 11Last Post: 1st Sep 2007, 00:32 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
