Results 1 to 9 of 9
    Aug 2007
    Kuwait
    hello
    i am having a problem with editing some of my movies
    and what i mean by that is after i cut the unwanted scene from the movie i cant cut the wanted timing from the subtitle with out losing the rest of the sub timing
    i tryed some programs that cut both of them in the same time like tempeng... but the result file size came too big
    so is their a method to cut a specifec timing from the subtitle and let the rest of it auto adjust ???
    please help me if u can and i ll check this post at least 3 times daily to answer any quistions about what i mean
    thnx in advance
    USA
    A little more information would help. What format is the audio/video in the file and what format is the subtitle file?
    And welcome to our forums.
    Aug 2007
    Kuwait
    thnx i am glad to be part of this great forum
    the video format is the reqular AVI
    and the subtitle SRT or SUb
    but its doesnt matter for the both of em because there is alot of programs that help in changing formats
    and just to clearfy what i mean
    in this topic https://forum.videohelp.com/topic283241.html they cutted parts from the video
    how can they adjust they sub after what they cutted
    and thnx for replaying
  4. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    It's easy to edit and adjust timing in subtitles using Subtitle Workshop.
    Edit the Avi, make note of the times you cut and then open the SRT in Subtitle Workshop.
    Select your new Avi as the "movie".
    You can go to each break, delete subtitles and move up the remainder by a given time to get them back in sync.
    There are many functions for adjusting times, individually or en masse.
    Spend 10 minutes reading the help file and you'll be fine.
    Aug 2007
    Kuwait
    thnx alan for replaying
    i have subtitle workshop for about 3 months now but i cant fegure out how to close the gap in the timing after deleting a section of the sub in the midd
    and some time the cutted section have no sub so it doesnt appear in the subtitle
    so if their was a tool or a method in subtitle workshop please text write the instructions about reaching it
    many thanks
  6. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Click the button marked "Help"
    This opens your browser on the help file.
    Scroll down to "Chapter 2: Time related features" and read it.
    It's all explained there.
    Aug 2007
    Kuwait
    thnx for your help
    but is there any easier method
    because to be honest i got lost in reading the help file
    thnx again
  8. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    This is what it says. If you can't understand it, I don't know any better way to explain it.
    To apply a delay, first load your subtitle, then click the "Edit/Timings/Set delay..." menu or press [Ctrl]+[D] keys. The delay dialog will pop up.
    Aug 2007
    Kuwait
    thnx alan
    after trying and failling for about an hour and a half i finally figured it out
    so thans for clearing that out for me
    by the way do you recomend any program for cutting the video
    i tryed SolveigMM Video Splitter but it dont allow me to move the video cursor bar as i want
    then i tryed virtualdub but i kept losing the sync between the audio and the video
    do you know any other good program that i can use
    many thanks in advanced
