I have a region 2 DVD and am using Mac the ripper to rip it but when i playback in my dvd player its telling me the region is incorrect??
Does anyone know what I am doing wrong
Results 1 to 18 of 18
Region Code Enhancement (RCE) http://www.dvdtalk.com/rce.html is a possibility if so set MTR's "RCE Region" to region two when ripping.
This http://www.mrbass.org/mac/dvd/mactheripper/ may also be of use. Also according to that guide is the "New region" (for the copy on your hard drive) set to ALL, this applies mostly to hardware playback with a DVD player and television NOT a computer. -
Hi
yes NEW REGION is set to ALL
I still can't get this to work though -
Are you by any chance trying to play it in a "sony" dvd player
Assuming you mean your standalone player seeing as you were not real specific. -
Do you mean region as in PAL vs NTSC. If the disc is from Europe then it might not play here.
http://www.hometheaterinfo.com/dvd3.htm
This forum thread tells how to convert the disc over, if you really want to do that much work. It would be easier to buy a new tabletop player.
https://forum.videohelp.com/topic292461.html#1662965 -
Yeah my new dvd player refuses to play pal even though it's a cheap one.
Yes I thinks its easier just to buy a DVD player that plays both!
Thank you -
that only applies to the play back device and you should look under dvd hacks https://www.videohelp.com/dvdhacks for your model the result may involve flashine with a specific cd or entering a code using the remote
Download myDVDEdit (free)
http://www.macupdate.com/info.php/id/16595
Open the ripped file in myDVDEdit and look to the lower right window. Tab across the top - cllick General, tab left hand side, click Dvd, and this will give you a list of the regions it should play in. Make sure ALL are checked, or do so yourelf. Save this file and then burn.
Converting DVDs from Region 1 (NTSC) to Region 2 (PAL)
By Astronautilus in forum Authoring (DVD)Replies: 8Last Post: 10th Feb 2012, 04:35 -
Region free DVDs..
By Superstar24 in forum Newbie / General discussionsReplies: 14Last Post: 5th Feb 2010, 23:47 -
Vista thinks dvds are wrong region...
By imaginaryduck in forum Software PlayingReplies: 8Last Post: 1st Oct 2009, 00:01 -
Cannot play any region dvds - tried with DVD43
By dvb in forum Newbie / General discussionsReplies: 4Last Post: 9th Dec 2008, 16:43 -
Region 3 DVDs in Australia
By AlanHK in forum DVD & Blu-ray PlayersReplies: 3Last Post: 2nd Apr 2008, 04:23
