PGCEdit stopped save changes after few edits.
When I try modify them it does not close after save and beeps.
Sometimes it gives this message:
I updated from version 7.3 to 8.4 - no difference.Code:nteger value too large to represent integer value too large to represent while executing "binary format I $val" ("4" arm line 1) invoked from within "switch $numbytes { 1 {return [binary format c $val]} 2 {return [binary format S $val]} 4 {return [binary format I $val]} 8 {return [binary for..." (procedure "d2c" line 2) invoked from within "d2c $value $length" (procedure "set_int" line 3) invoked from within "set_int buf 0x93 $::buttons::butsinfo($type,$vts,$vid,$cid,hlendtime) 4" (procedure "fill_sector_with_buttons_infos" line 21) invoked from within "fill_sector_with_buttons_infos $origsector menu $vts $vid $cid" (procedure "write_buttons_menus" line 45) invoked from within "write_buttons_menus $::dvddir $vts" (procedure "::menued::write_all_buttons" line 21) invoked from within "::menued::write_all_buttons" (procedure "::main::Write_DVD" line 86) invoked from within "::main::Write_DVD false" (command bound to event)
The point is, it allowed me first few edits. Then I replaced menu cell with Vobblanker to add missing sound then replaced again because I forgot sup and then after defining buttons and trying to add navigation it stops working shouting about some "integer too large to represent".
Results 1 to 1 of 1
Cann't tell it's possible don't tell anything.
PGCEdit Question
By billynews in forum DVD RippingReplies: 5Last Post: 17th Oct 2011, 04:02 -
MPEG-2 edit/save, edit/save, edit/save... cycle
By KZemunski in forum Newbie / General discussionsReplies: 8Last Post: 26th Dec 2010, 14:55 -
PGCedit fix menu buttons
By mark129 in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2008, 00:51 -
deleting menu buttons with pgcedit problem
By spiritgumm in forum Authoring (DVD)Replies: 5Last Post: 20th Apr 2008, 18:52 -
PgcEdit questions
By kshavo in forum Authoring (DVD)Replies: 9Last Post: 15th May 2007, 02:18
