    Aug 2007
    After applying the posted hacks for my dvd player (Zeinith XBV243) I now have a blue screen that jitters with the DVD flash csreen visible. Movies also play but the screen is like a vcr that has the tracking very badly set and the color is also shifted to blue. Im sure I messed up the hack some how. So is there any one is out there that can help me get back to square 1, maybe a firmware reset hack???? Please Help me!!!!!
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    You're only option would be to apply the hack again, only this set it back to the original region (likely region 1 for you)
    Before doing that, you may want to verify all of the video settings (in the video setup menu).
    Google is your Friend
