    Aug 2007
    i got a q when i change the res on the movie the screen sizes dont change y is this how do i change the size of the screen in fairuse becuase somes r full screen and i cant get it to wide screen becuase the res dont change the size can i zoom or anything wit fairuse or anything i really need help
  2. Member DJRumpy's Avatar
    Dallas, Texas
    You should post your question in the main forums. I don't think it belongs here at all.
    Impossible to see the future is. The Dark Side clouds everything...
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    zookeeper 525: Please don't hijack threads. If you have a question, start a new thread. If you have a reply - reply in the old thread.
    Also - Please try to use punctuation and capitalization. It makes your posts easier to read, understand and answer.
    /Mats
    Apr 2004
    Miskatonic U
    Aside from actually using words instead of letters, you might also give some details.
    What is your source ? 16:9 ? 4:3 letterbox ?
    What are you trying to output to ?
    What are you playing back on ?
    Post g-spot shots of the source and the output from FairUse
    Have you tried AutoGK ?
    You seem to be saying you have tried several programs and none of them work. This usually indicates that something else is wrong in your process or the way you watch the files. The number of times someone has posted here about how a program doesn't work properly, only to have it pointed out that their player was configured incorrectly, are many.
    Read my blog here.
