I already have memory, case, and all the drives all I need is a motherboard/cpu combo. All I am looking for is something where I can be able to multi task without a bunch of lag. Something where I can watch a 720x480 vid without lag, or a dvd vid. Any ideas? Ebay, etc?
Results 1 to 9 of 9
It would be helpful if you posted what type of memory that you already have. Is it DDR 400 (pc3200)? DDR2 667 (pc5300? DDR2 800? Different sockets use different ram. For example Intel socket 478 & AMD socket 462 can use DDR 333, DDR 400 & DDR 266 ram. Newer sockets like Intel 775 & AMD 2 can use DDR2 667 & DDR2 800 ram.
I'd suggest buying a motherboard/cpu combo from a reputable online retailer like NEWEGG.
capman21,
It would also help if you gave us a price point. There is a large range out there. You could get a basic AMD X2 w/ mobo for $125 or less to fit your needs and go all the way to $1500 for top o' the line stuff. Both ends of which would take care of your needs. Nothing you've described is very taxing.
I just picked up an (albeit aging...ok, close to being ancient) AMD motherboard w/ AGP (didn't want to upgrade the video card yet...) and an AMD X2 3800 for $130 total. Except for some hard to find stuff, I've been buying exclusively from Newegg for a few years now.Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
I just bought these 2 motherboards
http://biz.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=2353753
http://biz.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=2823998
I bought the second one to replace a Biostar (crap) Via motherboard -
For that type of ram and the price range it be best to just purchase a AMD socket 754 processor with a socket 754 motherboard. Here's a example of what you could buy in that price range:Originally Posted by capman21
AMD socket 754 2600+ Palermo 1.6ghz processor, $29.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819104249
MSI K8N Neo3 H nForce4 Socket 754 ATX Motherboard, $34.30
http://www.geeks.com/details.asp?invtid=K8N-NEO3-H-PB&cat=MBB
ASRock K8NF6G-VSTA 754 NVIDIA GeForce 6100 Micro ATX AMD Motherboard, $55.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157098
Unfortunately the type of ram you already have is considered obsolete because of the new and faster processors in the market. If you want something faster than a AMD socket 754 then you'll have to spend more money than $125.00.
You could get a OEM Intel socket 478 processor and motherboard like this:
Intel socket 478 OEM 2.8 Northwood processor, $74.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116215
BIOSTAR P4M80-M4 478 VIA P4M800 Micro ATX Intel Motherboard, $64.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138262
You are very limited in what processor and motherboard that you can use with DDR 400 ram.
What ever you do, don't get the VIA P4M800-M7 AOriginally Posted by budz
By far the worst board I've ever had.
I'm replacing it with a Intel D945GCCRL -
Only made that suggestion the OP if he decided to get a socket 478 mobo. I have that mobo as well & had to rma to get a new one. I'm not just not ready to give up my socket 478 NORTHWOOD 3.0c cpu yet. I didn't have much of choice when I needed to replace a ASUS P4P800SE mobo.Originally Posted by stiltman
I didn't want to mess with RMAing, so I'm pretty much replacing all boards that are not Intel or Asus with Intel boards.Originally Posted by budz
BTW, my favorite board is Intel D945PVSLKR
However, with my new personal build, I'm going with DG965WHMKR
It's a very versital board, but it lacks the firewire headers. I'll be putting a 3 port ADS card in it
Computer build questions on motherboard brands and cpu specs- vid encoding
By yoda313 in forum ComputerReplies: 68Last Post: 31st May 2011, 07:55 -
CPU (125watts) + MotherBoard (140watts) = ?
By eskro in forum ComputerReplies: 2Last Post: 29th Jan 2010, 18:48 -
can anyone recommend a wireless keyboard and mouse combo?
By mrgain in forum ComputerReplies: 3Last Post: 15th Jul 2009, 11:00 -
CPU fan spins, but no motherboard beep
By gooberguy in forum ComputerReplies: 23Last Post: 30th Jun 2009, 16:54 -
Matching CPU/Motherboard FSB to RAM Speed?
By rkr1958 in forum ComputerReplies: 2Last Post: 24th Jul 2007, 21:25
