Sometimes I just want to convert 20 files, and since there are no batch mode, can ffmpegx at least give me the command that it is using so that I can script it through shell?
The command is copied to the clipboard, but it's wiped out by the date which is copied right after it. However, if you install something like Jumpcut:
http://www.macupdate.com/info.php/id/21604/jumpcut
You'll be able to see the command in the clipboard history.
B.
If you're looking to convert 20 files, all with the same settings, then take a look at Quick Batcher at www.emmgunn.com. Make the settings you want in ffmpegx, then drag and drop all your video files into Quick Batcher and it'll quickly enter your conversion jobs in ffmpegx's queue. It'll also let you do the same with multiple titles in a DVD.
JumpCut doesn't seem to work for me. Actually, let me refine that statement: JumpCut works in as far as it's supposed to with the other apps that I use - but it does not seem to capture the command line that ffmpegx generates. I tried replacing the ffmpeg binary inside the application package with something that would capture the command line that way and that wouldn't work either. Does anybody have any suggestions as to how to determine what parameters are being passed to ffmpeg?Originally Posted by emmgunn
when ffmpegX is running, open up a normal Terminal window and type:
ps auxww | grep ffmpegX
and you'll see just the processes running that have the string 'ffmpegX' in them.
Copy / Paste the bits you want into a file.
J
Command-line command for fixing AVI?
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 02:23 -
ffmpegX command that is run...
By none_dito in forum ffmpegX general discussionReplies: 2Last Post: 21st Jul 2008, 18:56 -
command line
By exekutive in forum ffmpegX general discussionReplies: 22Last Post: 1st Jun 2008, 23:44 -
Get corresponding ffmpeg command after using ffmpegX
By npw in forum ffmpegX general discussionReplies: 2Last Post: 23rd Apr 2008, 01:29 -
RDP command
By mike909 in forum ComputerReplies: 0Last Post: 15th Jun 2007, 18:51
