Results 1 to 9 of 9
    Jul 2006
    i have an avi file and my dvd player is capable of playing avi files but should i convert to any other format to increase quality or should i keep the avi as it is.
    also how would i burn the avi onto a cd-r should i just drag n drop it into my optical drive??
    thanks.
  2. Generally you can't increase the quality of a video by converting it to another format.
    Use your DVD burning software to create a data disk with the AVI file(s). Players vary a bit in their file system support but ISO or UDF format usually work.
    And don't create a multisession cd as it might not work that well.
    Jul 2006
    okay thank you very much
    EDIT: how can i add switchable subtitles the user manual of the dvd player says it supports subtitles in divx discs so do i include the subtitles in the iso?
    thanks.
  5. Banned
    Freedonia
    And the reason you decided not to give us the model of your DVD player was ... ? That might have been helpful. Anyway, it depends on your model, but generally you just need to name the subtitles the same as the movie. For Philips players, you don't have to do this, but some players do require this. For example you might have files on DVD called:
    MYMOVIE.AVI
    MYMOVIE.SRT
    with the SRT file being the subs. Not all subtitle formats are supported - it depends on the player. With Philips you have to select the subtitles file with the Subtitles button on your remote BEFORE you play the AVI file. Again, we don't know your DVD player model, so things may be different for you.
    To burn you just make a data disc with the file as your content. I agree with Baldrick - NEVER make a multisession disc for playback on a standalone DVD player. Most players will only see the first session and nothing else.
  6. Originally Posted by jman98
    Not on the DVP-5960. Pressing the subtitle button while the video is playing is enough. You can cycle through different subtitle files by pressing the button repeatedly. The srt files don't even show up on the player's file listing.
    Jul 2006
    sorry for not giving the dvd player model its a toshiba sd27e
    but what i need to know is when making the iso do i include both the video and the subtitle in the iso or just the video and then the subtitle file seperatly.
    thanks for your help so far.
  8. Put the AVI and SRT in the same folder.
    What software are you using to make your disks?
    Jul 2006
    i was going to use alcohol 120 to make the iso.
    should i use anything else?
    thanks
    EDIT:
    i made a disk by simply dragging and dropping my avi file into my cd writing drive and the disc can be played back on my dvd player so i guess theres no need to make an iso or any other image. so i can just put subtitles on in the same way.
    thank you for all your help guys.
