Any opinions on the Sima Color Corrector SCC-2 ? I have an AVT-8710 with built in proc-amp controls, will it give a better picture correction than that ?
Hello I have both of those units. The avt 8710 is a time base corrector along with a built in proc amp. The SCC2 is mainly just a proc amp and it does a more thorough job of color correcting then the avt8710 but thats about it. The SCC2 does nothing much as far as the sharpness option goes. I have not seen much difference in the before and after look. The avt does not do much better but seems to give a little more detail. The avt 8710 will give you time base correction but the SCC2 will not help you there as it does not have built in time base correction. I mostly use the avt 8710 and have only used the SCC2 only a few times. It seems to have a problem with the tinting of it going darker and lighter at times mostly with vhs tapes. I hope that helps you out. I would go with the avt 8710. It does a nice job for adding just a little color if you need it.
Eric -
I hope this one is a lot better than their CT-2 or CT-200, which (judging by my unit of the latter) really blows. Lots of random color and brightness shifts, and generally useless. I'm sure there must be better proc amps out there, for about the same money.Originally Posted by heman31Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
Color Corrector
By cynikalhedonist in forum EditingReplies: 8Last Post: 25th Jun 2010, 12:49 -
[color=blue]video oediting software for ASUS Eee PC (white ones)[/color]
By helpmepls in forum Newbie / General discussionsReplies: 1Last Post: 6th Feb 2009, 07:53 -
Color shift in ffmpeg X - ffmpegX native color space and gamma?
By rbot1980 in forum ffmpegX general discussionReplies: 0Last Post: 2nd Feb 2009, 21:16 -
Diff. between Sima SCC and SCC-2 ?
By Seeker47 in forum RestorationReplies: 0Last Post: 10th Nov 2008, 12:51 -
Programs capable of muxing .scc with .mp4?
By FallenAngelII in forum SubtitleReplies: 1Last Post: 11th Dec 2007, 05:34
