I use 5.1 channel audio for the DVDs I make with Pinnacle Studio 10.
If you make first a file (avi or mpeg) from your project with 5.1 audio instead of straight burning the project to DVD, is the 5.1 channel audio kept when later-on converting the video-file to DVD.
Or is the 5.1 audio only available when converting a project directly to DVD ?
thanks for your feedback.
Gerrit
If you check Pinnacle10 specifications it is able to export 5.1 audio.
So if you import 5.1 into your project, your DVD should be with 5.1 sound.
I do not get what you mean "converting later-on", but you have to be careful if you use other software to make DVD, because some convert 5.1 to 2 channel stereo, like TMPGEnc.
PINNACLE STUDIO 11 - dvd no audio plays
By ancient in forum Authoring (DVD)Replies: 2Last Post: 10th Jan 2012, 09:07 -
Audio Effect help needed (Pinnacle Studio 11)
By JohnP in forum EditingReplies: 0Last Post: 5th Apr 2011, 05:44 -
Pinnacle Studio UltimateHDv14-audio out of sync!
By rivrbyte in forum Capturing and VCRReplies: 0Last Post: 20th Mar 2011, 22:42 -
No audio with pinnacle studio 12.1 on vista 32 premium?
By yoda313 in forum EditingReplies: 0Last Post: 26th Oct 2008, 16:05 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 19:53
