When I attempt to back up my dvds the buffer bar fills up and it says "writing lead in" but then nothing happens. Does anyone know how to help?
Results 1 to 13 of 13
I got this msg after I unplugged my external HP 740e drive.
creat file failed
device: '\\. \Cdro4'
Reason The system cannot find the file specified.
what other info can I give you? -
What exactly are you trying to do? It is not clear from your post. Are you trying to burn a iso with dvddecrypter? Give all the info you can about your method.
Donadagohvi (Cherokee for "Until we meet again") -
yes thats it exactly. Im trying to burn a dvd movie onto a blank dvd disc. Im using a dual layer disc. and Im using dvd decrypter. but when I attempt to put the movie (iso) onto the disc it says that somthing about the lead, and nothing happens with my external drive. then I it cancle and it says "abort agknowleged" and nothing happens... So i unplug my drive, then my computer snaps out of it...
how are memorex DL dvd's? I tried to burn superman returns and it stoped at 50% on 4 different discs. I dont understand whats going on...
Originally Posted by sono
Because MEMOREX DL DVD media is crap that's why you're getting discs that cannot be burned completely. As I've already suggested buy VERBATIM DL DVD+R media and burn with IMGBURN then you'll be fine. I don't understand why people buy crap dvd media and expect it to burn correctly when it doesn't.
you must be right. Upon your advice I went and got a 3pk dvd+r of verbatim, and guess what... IT WORKED.... too bad they are so damn expensive. Whats up with that, I thought I bought a burner that would be fairly versitile... My friend has a crappy dell and it reads WINDATA... I doubt you have even heard of that. He has no problems with any media he buys....
I guess your right Thank you all for your help. Im a newby, I have no idea what the hell im doing, I just want to "back up" some dvds. If there is anything I can do to help the forum please let me know.
On a side note. How do the HP740e drives work, I mean as far as quality and all that. What is a good brand to buy? I think I may want to sell this one and try for a better more versitile drive. -
Glad to hear you bought VERBATIM DL and they work for you. As for other brands of dvd burners I'd suggest PIONEER 112D or LG-H62. Take a look at the forums at Cdfreaks.com. They have a PIONEER, LG, SONY/LITEON, SAMSUNG, PLEXTOR, BENQ/PHILIPS, NEC & BTC forums. Check it out!
DVD Decrypter: Unable to find VIDEO_TS folder
By sooojaded in forum DVD RippingReplies: 4Last Post: 9th Sep 2011, 19:51 -
Why is HD Decrypter of DVDFab unable to back up the Disney movie Up?
By coody in forum DVD RippingReplies: 1Last Post: 22nd Nov 2009, 13:04 -
Backup of a dvd movie using Ripit4me, Dvd Decrypter, and Dvd Shrink 3.2
By Gerald Sr. in forum DVD RippingReplies: 18Last Post: 16th Oct 2008, 16:55 -
Unable to burn DVD, unable to access the Video_TS.ifo.
By Asymmetry in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2008, 00:02 -
Can't backup blu-ray with DVDFab HD Decrypter
By Megahurts in forum DVD RippingReplies: 2Last Post: 25th Aug 2007, 22:50
