    Mar 2006
    Hi guys,
    My DVD player can read and play the DVD well. However, when I insert it to my PC, the PC can not recognize / play the DVD. When I use DVD-Shrink, it says "Insert the disk..." though the disk is already in the drive.
    Please help me with this problem.
    Thanks,
    Mike
  2. ...C O P Y L E F T JohnnyBob's Avatar
    Feb 2007
    Earth
    I've had that happen too occasionally, maybe 1 in 50-100 DVD movies, and never discovered the cause. However I have almost always been able to read such DVDs eventually by trying many times, maybe as many as 25-50 times. That's one reason why I now have two DVD drives in my PC, different brands/models, which helps to quickly rule out a drive malfunction.
    It might also help to clean the DVD.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Commercial disc ? Burned disc ?
    Does only Shrink have the problem ? Can you see the disc using Windows Explorer or DVDFab HD Decrypter ?
    Read my blog here.
  4. Member classfour's Avatar
    The Heartland, United States
    clean the disc
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  5. Member classfour's Avatar
    If cleaning doesn't work - you'll have to try a different drive.
    Your player doesn't have a problem, just the burner.
    Many burners do not make good readers - lesson learned (by me)
    Mar 2006
    I have tried to clean it up, but the result has been unchanged.
    That is a Musical DVD I bought from a store. Can not use any software in my PC, because even the disc is already inserted into the drive, the PC can not recognize.
    Thanks for all of suggestion.
  7. Member Cunhambebe's Avatar
    Mar 2004
    São Paulo - Brazil
    I have experienced the same problem around here.
    Mar 2006
    Hi folks,
    I've experienced that my burned DVDs are working fine with my PC, but the original one are not.
    Any suggestion would be appreciated.
    Mike
