Hi,
I've managed to create srt. file and corresponding avi.
i followed the tutorial in the how to's on creating selectable subs. I ended up with a single avi file.
I played this back on my vlc player but i am not able to turn the subs off.
can anyone help with this?
I am on a mac osx10.4 intel, i used mac the rip to strip, handbrake convert, d vision and d sub to create srts.
I am very new to this :P
Thanks.
Please wait a few days before you bump a topic (reply to it).
What tutorial did you follow? -
sorry! i didnt know it was bad etiquette..
the one on this page:
http://www.ffmpegx.com/dvd_sub.html
thanks. -
That tutorial is for creating a DVD with selectable subs. It doesn't seem to pertain to the question you're asking, but in answer to said question, VLC looks for an exact or similar named subtitle file which corresponds to the avi in the same folder. If one's there, it will typically display it automatically unless directed not to.
Plenty of options here. Remove the subtitle files from the folder...choose to turn off "Autodetect subtitle files" in VLC prefs...hit the letter S while playing the avi as this is the key command to rotate/turn off a subtitle track(s). Finally, you could also head to the video menu, drop down to "Subtitle tracks" and deselect it.What exactly is rotten in Denmark? -
yes... yes! Hello!!!!!
I did it after days of fiddling, perfect. Thanks so much,
Stalker.
!!!3D playback with VLC, MPC, WMP, HELP!!!!!
By NateDizzle in forum Software PlayingReplies: 6Last Post: 17th Feb 2012, 19:31 -
Issue with AAC: Only VLC can playback
By ripp3r07 in forum Newbie / General discussionsReplies: 6Last Post: 19th Dec 2010, 13:54 -
Two seperate VLC playback issues
By ecc in forum Software PlayingReplies: 13Last Post: 25th Sep 2009, 06:36 -
menus with VIDEO_TS playback in VLC possible?
By wcndave in forum Newbie / General discussionsReplies: 4Last Post: 12th Jul 2009, 09:37 -
Correcting VLC 5.1 Playback problem
By Millwood in forum MacReplies: 2Last Post: 15th Mar 2008, 09:12
