Hi,
I captured some dv footage a while ago using generic firewire, then captured some different footage using Matrox RT2500, is it possible that there would be a difference with quality of capture using these different cards?
"Smoke Me A Kipper, I'll Be Back For Breakfast!! :D
The "capture" is actually a file transfer, so there should be no difference in quality. Depending on the driver software, you might capture one in DV Type 1 format and the other in DV Type 2 and those are treated differently by editing programs. One format can be converted to the other with no loss of information.
What is the difference between onboard & stand alone video cards ?
By Illusionist in forum ComputerReplies: 18Last Post: 22nd Dec 2009, 20:05 -
DVDfab generic settings
By EliteMarine in forum DVD RippingReplies: 2Last Post: 3rd Sep 2009, 19:17 -
What is the difference in connection of DV and pc between USB and FireWire?
By coody in forum Capturing and VCRReplies: 2Last Post: 11th Dec 2008, 15:17 -
Win98 Generic drivers?
By bevills1 in forum ComputerReplies: 4Last Post: 30th May 2008, 15:44 -
R there good and bad firewire PCI cards??
By sdsumike619 in forum Capturing and VCRReplies: 3Last Post: 3rd May 2008, 16:25
