Hi,
I'm using Roxio Easy Media Creator 8 to create slideshows and burn to a DVD. I'm using Sony DVD-R discs. The DVD plays on my computer but won't play on my DVD player. I have a Sony DVPNS90V DVD player. (The region code is 1 on my player and my computer).
The error message I get is c:13:70 the disc is dirty.
I checked the manual and it is compatible with DVD-R discs.
Please help
Randy
	Welcome zenfoos
 Get a reasonable optical disc cleaner for the unit ... most just push dirt about ... not much cleaning actually takes place .
 Try different media is mentioned about ... but try output to folder only first , then us imgburn to burn the output to those sony discs , at 4x , and see what happens .
	From other posts here in the forum, the Sony players seem to be finicky about the brand/type of media that they support. Others have reported having issues using the Sony media. Look up your player in the DVD Players section and see what brand/type of media others have had success using. Google is your Friend
	Thanks for the feedback.
 It was a media issue. Couldn't find Vebatim so I bought some Philips DVD+R and it worked.
 Funny that Sony DVD-R won't work in my Sony DVD player. I did read somewhere that Sony players like the "plus" discs better.
 Thanks again.
	That's very Sony. The only CDR ever de-laminated on me was also Sony.
 Care for Sony lithium-Ion Battery ?
  Problem Playing Authored/Burned Dvd on DVD PlayerBy djgazzabhoy in forum Video ConversionReplies: 10Last Post: 24th Nov 2011, 15:15
  No sound when playing playing burned DVD on stand alone playerBy ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 14:11
  problem playing burned .iso dvd in my dvd playerBy method in forum DVD RippingReplies: 6Last Post: 5th Dec 2007, 07:12
  Problem Playing DVD I burnedBy hollywoodfussell in forum Newbie / General discussionsReplies: 4Last Post: 8th Sep 2007, 08:46
  Ripped/burned AVI DivX files not playing in pc or DVD playerBy perceptionist in forum DVD RippingReplies: 13Last Post: 4th Jun 2007, 04:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
