trying install virtual dub because i am haveing probs with mainconcept,trying to get the audio source to work,i was on the forum last nite,
was told to try virtual dub
but everytime i try to in install ,i get messages like avifile framclient install failed or couldnt read source file"vdremote.dll
help pls
thanks peter
VirtualDub doesn't install, it just runs from the .exe. That sounds like you might be trying to run the wrong file in VD. That sounds like the frameserver, not the VD program. But I would try VD Mod instead as the audio handling seems to be a little easier. All the VDs work about the same way.
This is the VD program. You just click on it and it should start with no installing.
I would install the newest version of Virtualdub 1.7.3. It's in beta but I have had no problems with it. It has features that none of the other versions have.But I would try VD Mod instead as the audio handling seems to be a little easier. All the VDs work about the same way.
VirtualdubMod is no longer updated. The latest version is over a year old (1.6 Aud-X Surround).
Virtualdub MPEG-2 handles MPEG-2 files and WMV files. FccHandler just made a minor update but says he probably won't update it anymore. There is a slight chance that he will update it to the new beta version once it reaches stable release if Avery doesn't put features from the mods into a future release which is also a possibilty.
I have about 10 versions on my machine and keep a shortcut on my desktop for Version 1.7.3, VDub MPEG 2 1.6.19 and VirtualdubMod 1.6 Aud-X Surround.
Need to Remove Logo for a set time at a set place.
By Ensign in forum EditingReplies: 3Last Post: 11th Sep 2009, 16:39 -
x264, set quantizer to 10 and vary keyinterval to reach set target bitrate?
By frifox in forum Video ConversionReplies: 6Last Post: 20th Feb 2009, 16:59 -
VirtalDub ERROR - plz help
By UmmAddan in forum DVD RippingReplies: 3Last Post: 30th May 2007, 18:52 -
Why does VirtalDub joined AVI become so huge?
By Pitman in forum Newbie / General discussionsReplies: 3Last Post: 13th May 2007, 13:17
