Page 2 of 2
FirstFirst 1 2
Results 31 to 60 of 60
  1. Banned
    Jun 2001
    UK
    Ok I'm back, cant find it to delete it, however there seams to be another problem.
    Tried to change my personal picture, several attempts to upload a new one, nothing seam to happen, then tried to link to one, that did not work.
    <<< Even tried reducing size below 6K, ended up with what you can see now !!
    Linking is not possible. Try upload it again because it should work, remember that it is both a 6k limit and a height and width limit.
    okey it doesnt work anymore...
  4. Banned
    Jun 2001
    UK
    Yep, its working again
  5. Banned
    Jun 2001
    UK
    So What happened ?
    Rather interesting page view
    Welcome to cheats.st Have fun Paul!
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    the apache server automatically restarted and when it started it just pointed to another user on the server....but it should be fixed now.
  7. Banned
    Jun 2001
    UK
    Ok I found a bug
    Type some text in a post, but then think (Ill make that bit bold etc)
    Place the cursor where you want the bold to start and hit the B* icon.
    The [ b ] is placed at the end of the text ?
    And if its a long post you won't even noticed it happens same with the others.[/i][/b]
  8. Banned
    Jun 2001
    UK
    And if you change your mind, and remove the [ b ] then hit post like I did above and it adds the closed function anyway.
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    i think it is not possible to fix...or else would the phpbb creators already have done that. but you are welcome to check it out
    here is the javascript code
    function bbstyle(bbnumber) {
    	donotinsert = false;
    	theSelection = false;
    	bblast = 0;
    	if (bbnumber == -1) { // Close all open tags & default button names
    		while (bbcode[0]) {
    			butnumber = arraypop(bbcode) - 1;
    			document.post.message.value += bbtags[butnumber + 1];
    			buttext = eval('document.post.addbbcode' + butnumber + '.value');
    			eval('document.post.addbbcode' + butnumber + '.value ="' + buttext.substr(0,(buttext.length - 1)) + '"');
    		imageTag = false; // All tags are closed including image tags :D
    		document.post.message.focus();
    		return;
    	if ((clientVer >= 4) && is_ie && is_win)
    		theSelection = document.selection.createRange().text; // Get text selection
    	if (theSelection) {
    		// Add tags around selection
    		document.selection.createRange().text = bbtags[bbnumber] + theSelection + bbtags[bbnumber+1];
    		theSelection = '';
    		return;
    	// Find last occurance of an open tag the same as the one just clicked
    	for (i = 0; i < bbcode.length; i++) {
    		if (bbcode[i] == bbnumber+1) {
    			bblast = i;
    			donotinsert = true;
    	if (donotinsert) {		// Close all open tags up to the one just clicked & default button names
    		while (bbcode[bblast]) {
    				imageTag = false;
    			return;
    	} else { // Open tags
    		if (imageTag && (bbnumber != 14)) {		// Close image tag before adding another
    			document.post.message.value += bbtags[15];
    			lastValue = arraypop(bbcode) - 1;	// Remove the close image tag from the list
    			document.post.addbbcode14.value = "Img";	// Return button back to normal state
    			imageTag = false;
    		// Open tag
    		document.post.message.value += bbtags[bbnumber];
    		if ((bbnumber == 14) && (imageTag == false)) imageTag = 1; // Check to stop additional tags after an unclosed image tag
    		arraypush(bbcode,bbnumber+1);
    		eval('document.post.addbbcode'+bbnumber+'.value += "*"');
    		return;
    	storeCaret(document.post.message);
  10. Banned
    Jun 2001
    UK
    Hi
    Don't see why it has to close them anyway, if you forget then nothing will go wrong, then the person will have to edit. change cont so that it never works would need to look at it more.
    I just installed RC4, so going to be a little busy dam apache was blocking read access to my avatar's, and I thought it was the new install..
    Submit the bug, maybe nobody has spotted it... Me I press, click thump, what does this do, on everything.
  11. Banned
    Jun 2001
    UK
    Any good ?
    <HTML>
    <HEAD>
    <SCRIPT>
    function storeCaret (textEl) {
    if (textEl.createTextRange)
    textEl.caretPos = document.selection.createRange().duplicate();
    function insertAtCaret (textEl, text) {
    if (textEl.createTextRange && textEl.caretPos) {
    var caretPos = textEl.caretPos;
    caretPos.text =
    caretPos.text.charAt(caretPos.text.length - 1) == ' ' ?
    text + ' ' : text;
    else
    textEl.value = text;
    </SCRIPT>
    </HEAD>
    <BODY>
    <FORM NAME="aForm">
    <TEXTAREA NAME="aTextArea" ROWS="5" COLS="80" WRAP="soft"
    ONSELECT="storeCaret(this);"
    ONCLICK="storeCaret(this);"
    ONDBLCLICK="storeCaret(this);"
    ONKEYUP="storeCaret(this);"
    Kibology for all.
    All for Kibology.
    </TEXTAREA>
    <INPUT TYPE="text" NAME="aText" SIZE="80" VALUE="Scriptology">
    <INPUT TYPE="button" VALUE="insert at caret"
    ONCLICK="insertAtCaret(this.form.aTextArea,
    this.form.aText.value);"
    </FORM>
    </BODY>
    </HTML>
  12. I'm a MEGA Super Moderator Baldrick's Avatar
    no...i want everything done so I can just copy and paste into phpbb....
  13. Hey Bladrick the reactivate your account thing is a bit annoying for people who use web based accounts....if you have a good reason i can understand
  14. I'm a MEGA Super Moderator Baldrick's Avatar
    reactivate??
  15. with your profile..when you change your profile i have to reactivate
  16. I'm a MEGA Super Moderator Baldrick's Avatar
    I dont, neither when I used my testusers....does it always happens whatever you change in your profile?
  17. Banned
    Jun 2001
    UK
    Reactivate only works if you change an email address or password, anything else and it should not do anything.
    Mine (In here) always works this way
  18. well i always put my password so that might be he problem...well dats ok
  19. I'm a MEGA Super Moderator Baldrick's Avatar
    it will only happen if you change the email. not by only changing password.
  20. Banned
    Jun 2001
    UK
    Ok, why is this happening.
    When I upload my avatar its transparent, but gets changed by the phpBB ?
    here is the original image I uploaded
    But as soon as its uploaded, the transparency goes
    Never noticed this before, I need to go and ask for my money back from those people
  21. Banned
    Jun 2001
    UK
    Well it must be RC2. As RC4 is OK, unless you have a mod on it.
  22. I'm a MEGA Super Moderator Baldrick's Avatar
    it is transparent for me.
  23. Banned
    Jun 2001
    UK
    That's because you nicked my picture and replaced it or fixed it.
    I tried several last night, having had it brought to my attention
  24. I'm a MEGA Super Moderator Baldrick's Avatar
    no i havent done anything.
  25. Banned
    Jun 2001
    UK
    Yer if you say so.... 8)
  26. Banned
    Jun 2001
    UK
    So what am I ?
    I can see the ranking is overflowing ?
    I think I should be
    a, "chief cook and bottle washer"
    b, "Mr. Big"
    c, "Better than the average bear"
    d, "Baldrick's main man"
  27. The forum search engine appears to be down. The search results say something like:
    • General Error
      Couldn't delete old search id sessions
      DEBUG MODE
    and then it list a bunch of weird text
  28. I'm a MEGA Super Moderator Baldrick's Avatar
    fixed.
  29. Member
    Feb 2001
    Berlin, Germany
  30. I'm a MEGA Super Moderator Baldrick's Avatar
    fixed the poll editing.
