How does one get rid of everything on an sata-ntfs-vista harddrive. I am trying to get the harddrive back to the way it was just "out of the box". Fdisk won't work. Is there a program similar to fdisk that will work on sata drives?
Try the manufacturer's website. Most (Western Digital, Maxtor, Seagate, etc.) have bootable disk (CD / Floppy) images that you can download, to check for hard disk errors. They typically allow one to do low level formatting operations as well.
Thanks for your help. I found a program called "Disk Wizard" that did the trick. I completely erased a 500GB harddrive in just two hours.
Question how to delete files that won't delete
By jimdagys in forum ComputerReplies: 18Last Post: 9th Sep 2009, 13:09 -
delete
By bigMach™ in forum Newbie / General discussionsReplies: 0Last Post: 18th Aug 2008, 06:15 -
How to delete old vista related folders
By joy in forum ComputerReplies: 8Last Post: 18th Feb 2008, 15:59 -
What is the difference between Vista basic and Vista home premium?
By davidsama in forum ComputerReplies: 18Last Post: 27th Oct 2007, 12:01 -
Sharing TV - 1 Vista Media Center Server to Vista Media Center PC
By JBredensteiner in forum Media Center PC / MediaCentersReplies: 8Last Post: 14th Jul 2007, 01:33
