Could anyone point me in the right direction to finding an app or utility that will de-interlace my XVID DVD-Rips. I have been backing up my dvd collection and the first 15 or so movies, I forgot to enable de-interlacing on the video encoding. Is there an app that exists that can de-interlace a video file without doing a full re-encode and leaving the audio stream intact?
Thanks in advance!
Surely you jest. I suppose that ffdshow can use some AviSynth deinterlacer or other, to deinterlace on-the-fly, but to fix it permanently will require a reencode.Is there an app that exists that can de-interlace a video file without doing a full re-encode
And that assumes it can be fixed, which isn't likely. If you've resized in the vertical direction, the chances are very good you've messed up the field structure and made fixing it impossible. And since you mentioned movies, the chances are pretty good that deinterlacing isn't what you want anyway. You probably should have IVTC'd these movies to begin with. Time for you to do some serious study about encoding movies, and start all over again. Either that or let AutoGK handle it until you learn something about encoding.
Want to rip from interlaced DVD's in highest/same quality!
By DARkTYranno in forum DVD RippingReplies: 17Last Post: 22nd Feb 2012, 17:05 -
BDrip x264 vs DVD-Rip XviD?
By therock003 in forum Blu-ray RippingReplies: 5Last Post: 9th May 2009, 15:38 -
Rip DVD to Divx/Xvid with AC3 Audio
By dudeman316 in forum DVD RippingReplies: 6Last Post: 3rd May 2009, 04:25 -
Interlaced XViD playback on Standalone - Field Order Problem
By nbarzgar in forum Video ConversionReplies: 2Last Post: 13th Jul 2008, 08:04 -
dvd rip better than original using Xvid?
By bmok in forum DVD RippingReplies: 11Last Post: 10th Aug 2007, 00:11
