It is 40% faster to use CloneDVD to clone a DVD to a hard drive folder and then import it from there for editing,
than it is to just import it directly from a DVD to one of those other programs.
Any downsides to that?
Interestingly, on another topic, I see if importing a DVD from a hard drive, it can also be 40% faster to save it (after editing) to a folder on another hard drive than to a folder on the same hard drive.
I think 40% is optimistic and certainly not the norm, however for large files there are certainly heavy saving to be had.
As for ripping DVDs to your HDD - it is essentially a file transfer, so if you have something that will do it faster then use it.Read my blog here.
I was talking about cloning the entire DVD to hard drive first then importing it from hard drive for editing
vs.
just importing it directly from DVD disc for editing.
As for 40%, I measured 40%
on my system.
_____________________
AMD Athlon XP 2500+ AXMH 2500 FQQ4C
IQYHA 0348 SPMW
2 x 512MB Centon PC3200 (Samsung chips) @ 9 4 4 3
[200] FSB x 12.5 = 2500 MHz @ 1.85 Vcore with memory frequency at 100% [200 FSB] @ 2.90 Vdimm and 1.6 Vdd
Epox 8RDA3+ v2.1, BIOS 07/29/2004
Thermalright SLK-900A with 80x38mm Delta EFB0812HHE fan
AIW 9600XT 128MB; Antec SX-835II case ; 380W Antec TruePower2 TPII-380
Five 80x25mm Case Fans -
I was talking going from drive to drive. It is certainly faster and simpler to rip to the HDD first, then loading it than working from the DVD drive. However I seriously doubt (and I have never seen) consistent savings in the 40% range when editing from one drive and saving to another. I still believe it to be good practice to work this way however.
Read my blog here.
Right. Exactly.
(My system is not RAID, btw.)
Operating system was on Western Digital 120GB Ultra ATA/100 7200 RPM SE (8MB)
And I measured 40% faster when importing a DVD from
Western Digital 250GB Ultra ATA/100 7200 RPM SE (8MB)
and saving to
Seagate 500GB SATA/300 7200 RPM (16MB) (Barracuda 7200.10)
vs. just using Western Digital 250GB Ultra ATA/100 7200 RPM SE (8MB) for both import/export.
IQYHA 0348 SPMW
Sony HDR-HC3 1080i question for importing & exporting - will help many
By sepman1 in forum EditingReplies: 9Last Post: 4th Mar 2009, 13:57 -
Codec choices for editing and exporting in Premier
By nhart1001 in forum Video ConversionReplies: 6Last Post: 8th Sep 2008, 19:01 -
Importing/Editing Video with Adobe Premier 6
By Namrepus221 in forum EditingReplies: 10Last Post: 12th May 2008, 22:30 -
Editing home videos w/ premiere and they look like crap after exporting...
By rockethobbit in forum Video ConversionReplies: 13Last Post: 17th Nov 2007, 20:36 -
Importing FLVs into a video editing software???
By J C in forum EditingReplies: 11Last Post: 27th Oct 2007, 21:04
