I have read some of the tutorial here on how to do this, But what is the best method and what's the standard method? I'm using tmpgenc, but when I convert avi/divx to vcd, the file mpg is slow larger then the .avi file. Is this how it's suppose to be or am i doing something wrong?
vcd is a constant bitrate of 1150 svcd is 2000+ so the files vary in size related to how many minutes the movie is.
well the avi file i have is 700mb, when i convert it to vcd, it is over 1gb
If you use the VCD template then you will get around 74 - 80 minute on a single disc. SVCD will give you about half that.
You can use a lower bitrate if you use the unlocked template and set it up yourself, however the quality will drop accordingly.
Any specific reason it must be VCD ?Read my blog here.
i like it as vcd and so i can author more then 1 movies or video on a dvd. Can you show me the best method to convert avi to vcd?
I like quality, so I haven't used the VCD format in many years.
Better solution, buy yourself a cheap Divx/Xvid capable player. Burn your avi files as data. You will get 6 standard 700MB movies to a DVD, without throwing away two thirds of the quality.Read my blog here.
well I downloa music videos and they are mostly in avi format, I use it for my car dvd player, so it plays dvd files only. Tha's y i want it in vcd format, then dvd author it to dvd.
Can't convert avi to vcd, svcd etc...Failed Message
By shankbone in forum ffmpegX general discussionReplies: 2Last Post: 10th Oct 2009, 01:12 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 10:56 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 10:27 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
