I have an ATI Radeon AIW and am trying to convert a bunch of all videos I have from VHS to VCD. I purchased the Sima Video CopyMaster, but it doesn't do the job that great.
I was looking at DataVideo's Time Base Correctors and wondering if anyone had used one and if they worked better.
Thanks in advance
It won't be better than VHS copy.
How's the result if you use the sima copymaster with VCR ? -
The CopyMaster stabilizes some of my videos, but only a very few of them. For some videos, it does get rid of the extreme jumpiness, but still has some slight jumpiness.
For other videos, it didn't look like it did anything. It has a signal indicator and even when that was at full, it would not always provide a good picture.
I thought a time base corrector would provide better stablilization than the copymaster (it costs more so should be better right).
I have two sima box's to get rip of macrowvision the Sima SCC this one is used to make DVD to tape copy can also be used TAPE to TAPE copy if you use this one to make a VCD the video get's choppy. I also have the sima copymaster it's about $50.00 dollars cheepper it has no problem's making a vcd when you go home dvd player to AIW card or dazzle the sima copy master is used to make Tape to tape copy you can not use it for DVD to tape you will get layer 2 of macrowvision with lines in the picture but when make a vcd layer two of macrowvision does not work on a computer as far as I know. You can buy thr Sima copymaster at any bestbuy store
<font size=-1>[ This Message was edited by: spiderman2k1 on 2001-07-22 15:32:55 ]</font> -
Anyone tried the $30.00 models? They're supposed to be updated to restore DVD as well as tape. They're basically a small box, with a battery (or AC adaptor) plug, and two RCA Jacks.
I had one of these before I smashed it inadvertently while moving, and it worked great for the longest time. Just wondering if they've made improvements over the years....
And are you sure you can buy a "Video Clarifier" at Best Buy? Seems odd to me... maybe because it only handles "Tape --> Tape", or "Tape --> Capture Card", no DVD?...
<font size=-1>[ This Message was edited by: homerpez on 2001-07-23 08:55:28 ]</font>
ION VCR2PC
By Gramps in forum Capturing and VCRReplies: 11Last Post: 1st Jun 2013, 20:23 -
Problems with capturing using ION VCR 2 PC
By mostly_useless in forum Capturing and VCRReplies: 0Last Post: 21st Dec 2011, 18:16 -
ION products anyone used them?
By victoriabears in forum Capturing and VCRReplies: 0Last Post: 14th Sep 2009, 00:04 -
ION cvr 2 pc
By twingdings in forum Newbie / General discussionsReplies: 0Last Post: 12th Jul 2009, 10:02 -
ION Turntable
By wulf109 in forum AudioReplies: 2Last Post: 21st Jun 2008, 07:41
