I'm looking to get an ATSC TV Tuner. I want to use it with an OTA HDTV Antenna. If it can pickup QAM signals as well that's a plus. I only have $100 to spend...unless someone thinks I should spend more. What should I get? There are so many options
Hauppauge HVR-950 maybe?
Pinnacle PCTV HD Pro Stick?
https://forum.videohelp.com/topic333289.html -
The Pinnacle PCTV HD Pro Stick looks good. Does it work with Windows Media Center? I want to set it up with WMC so I can watch HDTV through my 360
Apparently:Originally Posted by Deathwish238
http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/PCTV+Tuners/PCTV+A...V+HD+Pro+Stick -
Best to check for satisfied MCE users in the MCE forums. Never assume anything. These tuners are all new.
Plus don't expect QAM capability, look for successful experiences. QAM isn't supported by MCE yet anyway. You need to test with separate software like BeyondTV. Also, local QAM conditions vary by the local cable company.
HDTV ATSC Tuner Quality
By sambat in forum DVB / IPTVReplies: 5Last Post: 24th Nov 2011, 16:57 -
Could ATSC tuner be added to an old DVD recorder?
By yumagah in forum DVD & Blu-ray RecordersReplies: 2Last Post: 25th Feb 2009, 17:11 -
Dumping Comcast, looking for ATSC tuner card.
By gadgetguy in forum DVB / IPTVReplies: 25Last Post: 27th Jul 2008, 18:10 -
Are all US tv tuner capture devices going to ATSC models??
By yoda313 in forum Capturing and VCRReplies: 6Last Post: 13th Jul 2007, 15:26 -
ATSC Tuner
By ggr in forum DVB / IPTVReplies: 2Last Post: 8th Jul 2007, 00:17
