hi there .i was wondering if anyone could help me,i am trying to use mainconcept
when i select the video source the avi file comes up ok
but does not apear on the audio source .i have tryrd to manal selected it,but message comes up saying! no audio data found.
any idear am lost
thank pete
Drop the file into Gspot 2.70 and tell us the audio format. You may not have the proper audio codec installed or Mainconcept doesn't recognize the audio format.
If it's a AVI type file like Xvid or similar, you can probably extract the audio with a program like VirtualDub Mod and convert it to WAV format that most any encoder can use.
And welcome to our forums.
It happens to me fairly often when I convert PAL VOBs to NTSC. As was noted I simply use VirtualDubMod Surround 1.6.0.0 to save out the audio as uncompressed PCM.
ive just used gpsot 270 and it says
codec 0 x0055 mepg-1 layer 3
info 4800hz 139kb/s tot ,joint stereo lame 3.9
stat codecs intalled -
That seems to just be ordinary MP3 audio. Even if it was MP3 VBR audio, MC should have accepted it.
VBR might cause sync problems, but should still encode.
Depending on what you want to do with the file, you could use VDM as mentioned before to create a WAV audio and see if MC can accept the WAV file. Optionally for a DVD destination, encode just the video in MC, then take the WAV audio and encode it to AC3 with ffmpeggui or Aften and use that with the encoded MPEG-2 in your authoring program. But where you're at, MPEG-1, layer 2 audio is also acceptable and DVD compliant. Some instruction here for making WAV files with VDM: https://www.videohelp.com/forum/viewtopic.php?t=280779
Sometimes when you run into problems encoding the audio and video together, you can separate them and encode separately, then rejoin them afterwards. I use TMPGEnc DVD Author and it accepts separate audio and video streams, as do several other authoring programs.
I haven't used MC in some time. Maybe another member that uses it more often has some ideas.
need to replace audio source with a different source
By sec1968 in forum AudioReplies: 0Last Post: 6th Mar 2011, 22:59 -
main concept's cuda encoder released to public
By deadrats in forum Video ConversionReplies: 1Last Post: 17th Oct 2010, 19:33 -
Main Concept Pro HD4 work in CS5?
By darkztk in forum EditingReplies: 2Last Post: 6th Aug 2010, 23:00 -
main concept gains gpu accelerated encoding
By deadrats in forum Latest Video NewsReplies: 0Last Post: 5th Jun 2010, 16:19 -
How to full backup (no encoding) BR main movie, main audio with subtitles ?
By meico1234 in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2009, 03:37
