I am having problems burning DVD Files with nero.
As i add the Audio_TS and video_TS folders I am presented with the following message;
"The file VTS_01_01.VOB is larger than 2GB and therefore cannot be stored inb an ISO file system. Please use the UDF file system to write such large files. This can be done by selecting another compilation type"
The thing is readers I do not know what this message means, I dont know what ISO or UDF are and how would I select a different compilation type. Does it mean make it as a Data DVD instead ?
I am doing films the same way I have always done films and all are spot on so far.
Could somebody be so kind as to help me as I have about 11 films need doing.
I used WinAvi to convert the films from avi files to DVD files.
You don't need to add the AUDIO_TS folder, as it's empty anyway. If you are using Nero Burning ROM, just use the 'DVD ROM ISO' selection and replace the VIDEO_TS' folder there with yours.
But Nero should allow you about 4.4GB for a DVD.
Alternately, use ImgBurn and the 'Build' mode and use your VIDEO_TS folder for burning. It seems to do a better job burning than Nero anyway, IMO.
And welcome to our forums.
"VTS_01_01.VOB is larger than 2GB" = no can do for dvd specs , file max size exceeded .
Maximum vob size is a set standard , this is why nero threw the message up .
You need to demux that vob , and rebuild it correctly before nero will allow it .
Quick > demux title / vob with pgcdemux > rebuild with rejig or ifoedit or muxman > ready .
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2014, 11:24 -
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Nero only burning at 1x...?
By VEBouto in forum Newbie / General discussionsReplies: 2Last Post: 20th Jun 2008, 22:04 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 19:40
