Hi,
I"m new to HDDVD and need to know some basic question regarding burning HDDVD's.
1, Can HDDVD's be burned on NON HDDVD laptop (like sony FS 500) ? If not then what i need to do to burn it??
2 What tools are needed for backup and burning? can it be done by ripit4me/Dvd shrink and Nero?
3 What kind of discs are needed to burn HDDVD? will it work with the normally available dvd-r.
Would really appreciate if someone kindly let me know about it
thanks
1. Only to DVD. There is a method of burning HD DVD to standard DVD media and having them play in HD DVD players. They will not play in standard DVD players. You will also be limited to around 40 minutes running time a DVD-9.
2. AnyDVD. Standard DVD ripping tools, especially those out of production, like DVD Shrink, will not work.
3. See point one.
If you want to make full blown copies of HD DVDs then you will need HD DVD blanks and a HD DVD writer. You can write DVDs in a CD writer, and you can't write HD DVDs in a DVD writer. (and I don't want smart-arse responses about multi-format writers from the pedants. You know what I mean).Read my blog here.
Where is an outline of the method of writing hd-dvd to a dvd-9? I really want to try this!
also I hear you can put an hd-dvd to dvd-9 with h264?
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
Looking for an app that will backup HDDVDs or Blurays with minimal effort
By AndyD in forum Blu-ray RippingReplies: 24Last Post: 5th Dec 2009, 13:48 -
Blu-Ray & HDDVDs to Apple TV format...
By Matuna in forum Blu-ray RippingReplies: 1Last Post: 26th May 2009, 16:21 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
