    May 2006
    United States Of America
    Hi all,
    I have the first season of King Of The Hill on my computer and used DVDShrink to choose which episodes I wanted off of the first disc. That worked fine, but is there a way to select various episodes from the 3 DVDs that make up the whole first season? That is, how can I pick individual episodes across each of the DVDs, in order to make one single DVD? Is this even possible? There must be a way...?
    - Justin
    May 2003
    Peterborough, England
    DVDShrink. You've already done it with one disc, it's just the same for multiple discs. The only difference is that you'll have to rip them to your hard drive first and then open from there rather than from the disc directly.
    May 2006
    Thanks. They're already on my hard drive. I think I found the answer myself. Like a dope, I didn't see the "DVD browser". That's what I need in order to choose each VOB, right?
    Apr 2004
    Miskatonic U
    Once you have ripped all the discs to your HDD, open Shrink and go into Re-author mode. Drag the episodes you want from the first disc to the left-hand pane. Now open the second disc. Your choice fro the first disc remains. Drag the episodes you want form the second disc across and repeat until you are done, or the disc is full.
    The only issue with this method is you have no menus. Not usually a problem for movie discs, but may be an issue for episodic discs.
    Read my blog here.
    May 2006
    Thanks again... I'll check it out and report back.
  6. Member MysticE's Avatar
    Nov 2003
    To get to the next disc go from re-author mode back to Full Disc (to load the new one) then to re-author again.
    May 2006
    Thanks all... it worked like a charm
