I'm looking for some inkjet printable DVD's that also have a scratchproof coating on the bottom data layer. I've found TDK's scratchproof and Imation Forcefield discs, but neither are printable. It seems you have to choose between printable and scratchproof and also waterproof/smudgeproof.
Results 1 to 9 of 9
Delkin Gold with Scratch Armor would be the only one I know of. I heard they use MAM-A dye but can't say for sure. Not exactly cheap at $2.60 per disc.
http://www.adorama.com/ICDDVD47S100.html?searchinfo=delkin%20dvd-r&item_no=12
Others with anti-scratch coating, but not printable:
TDK Armor Plated or Medical Grade
Verbatim Videogard or UltraLife
Maxell Broadcast Quality
Imation Forcefield
Memorex Pro Gold -
Well, maybe not Delkin either. It seems they are showing the Gold ones without the Scratch Armor in the pic, so I don't know.
Aha! Here are some from Verbatim:
http://www.verbatim.com/products/detail.cfm?product_id=ACE36C5E-1143-3415-5F87C16B1DC5...F84BCB85E482E7 -
Ahh...I found those Verbatim Videogard printable discs online at MWave. Those are close to what I need. To make them waterproof, I suppose I can use a clear acrylic spray on top.
Are you pretty proficient at spraying? I'm not; that's why I'd rather have the Watershield discs. Hopefully TY will implement videogard too...
Those VideoGuard discs are far from scratch proof. They claim 40x more scratch resistant, it's more like maybe 4x from my experience.
Printable DVD Slipcover Templates
By nwo in forum MediaReplies: 0Last Post: 24th May 2010, 18:04 -
Printable Dual Layer DVD's
By ozab in forum MediaReplies: 3Last Post: 7th Oct 2009, 14:12 -
Glossy hub printable DVD+R
By PharmBoy in forum MediaReplies: 9Last Post: 27th May 2008, 09:06 -
Help with printable DVD's
By stantheman1976 in forum Newbie / General discussionsReplies: 8Last Post: 23rd Feb 2008, 10:47 -
Suggestion for printer for printable DVD's?
By stantheman1976 in forum ComputerReplies: 7Last Post: 17th Feb 2008, 15:23
