    Aug 2007
    Hi experts,
    I am getting an error when I try to open any avs file in VirtualDubMod.
    Error message is always: AVI Import Filter error: (Unknown) (80040154)
    I have tried these scripts:
    example.avs:
    colorbars(729,480)
    trim(0,300)
    killaudio()
    example2.avs:
    LoadPlugin("C:\DVD Programs\AviSynth 2.5\plugins\asharp.dll")
    MPEG2Source("D:\TEST\Small clip\temp\VideoFile.d2v")
    asharp(2,3,0)
    Any idea what I'm doing wrong?
    Thanks,
    Chris
    Apr 2004
    Miskatonic U
    You also need to load the DGdecode plugin that created the .d2v file
    Read my blog here.
    Aug 2007
    Yes, I did that.
    Both the C:\DVD Programs\AviSynth 2.5\plugins\asharp.dll and the D:\TEST\Small clip\temp\VideoFile.d2v files are present.
    Any other ideas?
    Thanks,
    Chris
    Apr 2004
    Miskatonic U
    Post the full script
    Read my blog here.
    Aug 2007
    These are the full scripts. This is my first time working with avs scripts so I wanted to just do a very simple ones. I have tried 2 scripts which are both listed below:
    example1.avs:
    colorbars(729,480)
    trim(0,300)
    killaudio()
    example2.avs:
    asharp(2,3,0)
    Thanks,
    Chris
  6. So, where's the DGDecode.dll plugin guns1inger said you needed and you said you had in the script? It should be something like this:
    LoadPlugin("C:\Path\To\DGDecode.dll")
    asharp(2,3,0)
    Read the QuickStart guide that comes with the DGMPGDec package.
    I got that first script to open, although I think you meant to say ColorBars(720,480). Do you even have AviSynth installed? To make sure, make an .avs called maybe Version.avs. Inside have just one line:
    Version()
    Try and open it in VDubMod and see if it gives you the AviSynth version you installed.
    Aug 2007
    Thanks everyone.
    1. I unstalled AviSynth.
    2. Reinstalled AviSynth using default directory names
    3. Selected all install options
    And it works perfect!
    I'm guessing I didn't select the needed install options the first time.
    Thanks,
    Chris
