Hi, I have an AVI captured from TV, video is XVID, audio is PMC. I want to convert it to AVI with MP3 sound. Im looking for something close to a one-click solution. Anybody any experience using “Switch”? If I need to extract audio how do I reassemble without losing synch? Any help appreciated.
Install Virtualdubmod and LAME ACM MP3 if you haven't got them already. Open the avi in virtualdubmod. Click on Streams -> Stream List. Right-click on the audio and select Compression. If Compression is not available for selection, choose Full Processing, then right-click and choose Compression. Select LAME MP3 from the list and click on Configure. Choose CBR 128 (or whatever bitrate you require). Click OK until you get back to the main Virtualdubmod screen.
Click on File -> Save AVI As. Make sure Video is set to Direct Stream Copy, and save a new version of the avi with MP3 audio.Read my blog here.
The new version AVI with MP3 has audio slightly out of synch after approx. 30 mins. play. Any ideas?
https://forum.videohelp.com/topic314909.html
Try
Avi_Gain_Regular.bat
But, if the sync starts going out after 30 minutes, you're probably going to have problems no matter what you do. You might have to cut the file and fix it where it starts to go bad. -
Didnt help with synch problem, but looking into audio adjustment in VirtualDub, thanks.
File conversion problems AVI to Divx
By kaptainm in forum ffmpegX general discussionReplies: 2Last Post: 10th Aug 2008, 19:21 -
conversion of powerpoint slides to .avi file
By poescp in forum Video ConversionReplies: 2Last Post: 21st Jul 2008, 02:23 -
Loss of Audio During Conversion from VOB to AVI file
By dpvisco in forum Newbie / General discussionsReplies: 1Last Post: 13th Jun 2008, 01:21 -
VOB file conversion to AVI...many questions
By tonyclem in forum DVD RippingReplies: 19Last Post: 7th May 2008, 10:39 -
Huge file after WMV to AVI conversion
By windranger in forum Newbie / General discussionsReplies: 8Last Post: 8th Apr 2008, 07:32
