They are multiple files with a .avi.001, .avi.002, .avi.003 etc etc.
Winrar doesn't recognize them. What app is used to unzip/unrar/join these types of video files?
They may still be .rar files, just messed up.
But you could make a copy of one of them and rename the extension to .avi or .mpg and see if a individual file would play. Or open it in Gspot. If so, maybe they are avi or mpgs and not .rar. Then you could use a program like filemerger and join them: http://home.versatel.nl/doesw000/FileMerger/
Make sure you have 'Hide extensions for known file types' unchecked in 'Folder Options' to be able to see and change the extensions. -
Originally Posted by Hank Kinsley
They're most likely HJSplit files as ntscuser says.
HJSplit is freeware and easily found with a quick search.
Once you've joined the files, be sure to check the filesize (should be the sum total of the all individual files). Unlike RAR files, you won't get an error message if a file is corrupted or missing. HJSplit will just join the files up to the point where the corrupted or missing file is.
It's also a good idea to check the file with g-spot. I've had files that seemed okay, but were actually corrupted (g-spot will note that the file is truncated.).
Oh...another thing...HJSplit doesn't compress the files in any way. So you can often do a quick check of the quality of the file (assuming it's a video) by renaming the first file (.001) to .avi or .mpg (usually doesn't work with wmv, qt or rm files) and previewing in MPC or VLC.
Hope this helps!
Xvid4PSP 6.001 encoding options?
By vampypiano in forum Video ConversionReplies: 3Last Post: 10th Nov 2011, 13:54 -
how to open 001-002.zip
By pcb in forum Newbie / General discussionsReplies: 5Last Post: 11th Jan 2009, 19:53 -
? .mpg.001 etc
By rotuts in forum MacReplies: 3Last Post: 4th Nov 2008, 23:55 -
batch joining multiple .001 files
By vitamine in forum EditingReplies: 8Last Post: 22nd Sep 2007, 15:57 -
Philips DVD963SA/001 firmware installation???
By stieven in forum DVD & Blu-ray PlayersReplies: 2Last Post: 1st Aug 2007, 09:44
