I am posting this for someone else. I'm pretty sure a full frame TBC will help this guy, but I wanted to ask the experts.
I recently transferred a VHS tape of my wedding to DVD. The VHS tape plays perfectly. At the end of the VHS tape, the video man added a slow motion scene from the original footage, followed with a freeze frame. It plays perfectly in VHS.
I transferred the video to DVD using a standard JVC consumer deck. Video tape in one side, blank DVD in one side, 1 button copy.
The transfer was perfect except for the slow motion scene at the end. When the DVD plays the slow motion scene, it jitters vertically. The freeze frame also jitters. It's very annoying.
Can this be fixed with time base correction? Would the fix be to the DVD, or to the VHS signal before it is converted to DVD? I have no idea what time base correction is, so any help or advice from someone knowledgeable would be very much appreciated. Thanks!
I don't know if it can be fixed with a TBC, but it might be a little expensive to find out unless you can borrow one. If the 'slow motion' scene is from the VHS tape, it might be easier to use a MPG editor, copy the same scene and make your own slow motion version. Same with the 'freeze frame.'
TBC explanation from Wikipedia: http://en.wikipedia.org/wiki/Time_Base_Corrector
Sony Z5 slow motion
By savadepa in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 27th Apr 2011, 08:09 -
smooth slow motion
By nitrobaorder in forum EditingReplies: 22Last Post: 18th Oct 2010, 06:19 -
Gui dvd author-jumping movie in fast motion scenes due to high video bitrat
By extent in forum Authoring (DVD)Replies: 8Last Post: 19th Feb 2009, 07:30 -
Slow motion
By Pliny in forum MacReplies: 7Last Post: 7th Aug 2007, 00:02 -
Slow Motion
By sbuckmybballs in forum Newbie / General discussionsReplies: 6Last Post: 21st May 2007, 02:16
