I got Toshiba Satellite A135-S4666 laptop about a month ago. it came with a copy of Windows Vista Home Basic on it. Unfortunately, Vista seems to have quite a few compatibility issues and it just seems to be an overall slower OS than XP. So, I tried putting XP on it but found that there were no XP drivers and the Windows Vista drivers simply don't work. I tried calling Toshiba but they told me I was pretty much out of luck as far as XP drivers were concerned. So I was wandering if anybody had experience in finding 3rd part drivers or any other ideas up their sleeves.
I had similar problems with a Toshiba A200... and yes, you do need to dump that Vista crap
There are various ways of installing drivers. One particular way is easiest, but I can't mention that here as it may violate microsoft end user license agreements. The hardest way is to search for each driver manually by device id - something I'm certain you don't want to do. Luckily it is often the case, that others who have had the same problem with the same model, post what they have found.
A quick search found this:
If you can't boot into XP, you may need an updated version with sata drivers. Hope this helps get you started!Hi I have an A135-S4666 too. Running Ubuntu Linux and XP on it.
I have this for Mobile Intel 945GM Express drivers:
http://downloadcenter.intel.com/Prod...ProductID=2301
Using Atheros AR5xxx 5.3.0.35 for wireless drivers:http://www.opendrivers.com/downloado...php?href=47456
Realtek High Definition Audio 5.10.0.5436
http://drivers.softpedia.com/get/SOU...ver-R170.shtml
SmartCard 2.0.0.6
Haven't looked
Intel Chipset 8.3.0.1013
http://downloadcenter.intel.com/Deta...13499&lang=eng
Realtek RTL8139/810x Fast Ethernet NIC
http://www.versiontracker.com/dyn/moreinfo/win/54582
I used a program called "driver genius" and it located the driver versions needed for this laptop. -
All of the official drivers are listed on their webpage: http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?moid=1757706&rpn=PSAD...ceghdgngdgnj.0
While those are mostly Vista drivers and won't help you, it will show you the hardware and models for which you need drivers. You can then go to each manufacturers website or use google.Google is your Friend -
hi i need a complete set of toshiba satellite A135-S4666 driver.
i've lost my cd. Anyone can help me??
With My Best Regards
Operahadi Jaya D.P
Mpeg-4 stutter freeze on laptop 1, laptop 2 plays fine- why?
By sevenofone in forum Software PlayingReplies: 1Last Post: 8th Apr 2011, 16:15 -
Help! Where Do I Get New Drivers?
By RayPaula in forum DVD & Blu-ray WritersReplies: 3Last Post: 13th Jan 2010, 09:13 -
Formatting laptop, how do i know if a laptop has wifi capabilities?
By ricardouk in forum ComputerReplies: 8Last Post: 21st Nov 2008, 09:24 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 19:40 -
using second laptop as a video in from laptop with broken display
By joycefitz in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2008, 23:56
