i have a CD RW lite-on SOHR-5238S and a DVD drive lite-on LH-160IP the problem is they are both showing up as just CD drives D and E when i go to my computer, but when i go to control panel they are listed correctly and says working, they will play CDs but the RW won't burn disks, anyone know why![]()
Both show "cd" in windows explorer = normal
What program are you using to burn to cd-rw , and brand of media ... some are better than other's which might indicate time to update firmware for the cd-rw unit to handle newer media .
Try imageburn to burn to cd , works for vista .
How much work has unit done , could be getting close to being worn out as well . -
yes both show normal in control panel but not showing as CD RW or DVD drive on MY COMPUTER, both will only work as a CD drives D or E, won't recognize a burner or DVD drive, i'm using windows XP
See that you are on Nero ...
You didn't say if you have the Nero DVD plugin that allows you to burn DVDs. -
DVD not a burner justa player, the CD is a burner, well it was until the DVD drive went in
If you added/changed/moved either of the drives after installing Nero, it may be detecting them wrong.
Usually, an uninstall/reinstall of Nero will correct the problem.Google is your Friend
Mov to mp4 won't work
By Klagar in forum Video ConversionReplies: 1Last Post: 15th Dec 2010, 11:07 -
Why won't my mic work on my camcorer?
By apples017 in forum Capturing and VCRReplies: 3Last Post: 12th Jun 2008, 05:05 -
ffmpegX 0.0.9x r2 just won't work under X.3.9 ?
By Jose Hidalgo in forum ffmpegX general discussionReplies: 1Last Post: 16th Jul 2007, 08:37 -
Why won't identical hard drive work in another identical PC?
By rijir2001 in forum ComputerReplies: 8Last Post: 25th Jun 2007, 09:12 -
Autoplay on PC won't work now
By gwoiler in forum Software PlayingReplies: 3Last Post: 31st May 2007, 15:36
