I can convert avi->wmv just fine, I can do 1 pass encoding just fine and FFMpeg writes the logfile (ffmpeg2pass-0.log) but when I do the second pass it says "Error while opening codec for output stream #0.0 - maybe incorrect parameters such as bit_rate, rate, width or height"
I have read all the FFMpeg documentation and read their email list support and there is no anwser to findCode:FFmpeg version SVN-r10159, Copyright (c) 2000-2007 Fabrice Bellard, et al. configuration: --prefix=/usr --enable-shared --libdir=/usr/lib --enable-pp --enable-gpl --enable-pthreads --disable-debug --enable-libmp3lame --enable-libfaad --enable-libfaac --enable-libxvid --enable-libx264 --enable-libtheora --enable-liba52 --enable-liba52bin --enable-dc1394 --enable-libogg libavutil version: 49.5.0 libavcodec version: 51.41.0 libavformat version: 51.12.2 built on Aug 21 2007 02:11:47, gcc: 4.1.1 20060724 (prerelease) (4.1.1-4pclos2007)
Please help
Regards
ChrisL
Results 1 to 1 of 1
Difference Between 1 pass & 2 pass encoding
By iqbal88 in forum Video ConversionReplies: 28Last Post: 29th Oct 2021, 06:19 -
advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-pass
By codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 22:11 -
ffmpeg 2-pass does nothing
By grv575 in forum Video ConversionReplies: 13Last Post: 6th Oct 2010, 21:24 -
Retrospectively check if One Pass or Two Pass Encoding was used?
By BenjaminBS in forum Video ConversionReplies: 4Last Post: 26th Nov 2009, 06:46 -
Need help with ffmpeg 2-pass VBR encoding
By SliderVF14 in forum Video ConversionReplies: 8Last Post: 14th May 2007, 19:03
