i am trying to find a video capture card for capturing halo 2 video does anyone have any recommendations of what to choose i am soooo clueless i was going to buy this. PNY Verto GeForce FX 5200 / 256MB DDR / PCI / Dual VGA / TV Out / Video Card
Any number of cards or external capture devices will work for halo2 .
But that device isn't "vivo / capture" type .
Where is game coming from ?
Xbox = fine
Xbox360 = fine , though watch out for game's using interlace output such as "gears of war"
From pc = never say never , but your pushing it , if using loop back type setup .
From one pc to another = fine
From pc to tv out , record to vcr = fine
Same , but dvd recorder = problems
Same , but cam type device = problems , some will , some don't .
Capture cards :
Avermedia dvd ezmaker pci / gold = simple , seems to handle "gears of war = xbox360 title" interlace with exception .
Have usb2 units that outperform others in quality but higher cpu spec's required (amd2400 runs just above 2gig/mhz) .
Leadtek WinFast DTV1000 , supports dvb ... will be testing for interlace input .
There are also a number of "cheap" pci devices , but quality can be varied .
Sourced from ebay , tigerdirect , others .
There are also "hardware" encoders , good for low end systems .
Ask yourself 2 questions .
A : Hardware or software encoder (hardware good for lower ended systems)
B : Future proof , selected device must support (pal-60 / nstc-59 if xbox360 is on future plans ) = ask manufacture , check drivers for current os .
Recommendation for Video editing/Gaming PC
By mr-scarface in forum ComputerReplies: 6Last Post: 18th May 2011, 18:19 -
Do you know any good site about copy gaming disc?
By coody in forum ComputerReplies: 2Last Post: 6th Jan 2009, 16:43 -
Sporadic signal losses while capturing analog gaming footage w/ camcorder
By Nintendo Fan in forum Capturing and VCRReplies: 0Last Post: 17th Oct 2008, 19:45 -
I need a good FireWire PCI card for capturing video.
By mob in forum Capturing and VCRReplies: 11Last Post: 1st Apr 2008, 02:19 -
Is there a video card that can handle both: gaming & video editing?
By randyannie in forum Newbie / General discussionsReplies: 11Last Post: 20th May 2007, 16:50
