  1. My Wmm wont' save my movie I created. I wanted to use a different program but i was in a rush. MY movie is 533 MB and i have 21 GB of space. I dont know why it keeps saying I either: dont have enough disk space, saving location is non existant, or im missing fils in my movie. I have enough space, no files are missing, and the location (my Documents) still exists. Please help!!!! I try to do just the some of the same clips i use in the movie, and just make a test file and that saves (exact same clips from unsavable movie). I dont get it. Please help! Need my files by Saturday (tomorrow!!!!!)
    LITEON man!
    Feb 2004
    Australia
    Checked your not saving as dv-avi ? ... 533mbs would result in a huge file output .
    What was the time length of test clip output that worked , and in what format was it saved into , then what was it's output size .
  3. well the time length of the one that worked was around 2 and ahalf minutes, well i dont what u mean with ur 2nd question but the clips were WMV clips that were coverted from MPEG by super. The output size, im not sure?
    LITEON man!
