Hello,
When I use VCDImager I get a log screen mentioning this, which might explain why buring with Nero results in not being able to FF/FRW or use the GoTo option;
++ WARN: mpeg user scan data: one or more BCD fields out of range for "forward_I_offset"
++ WARN: mpeg user scan data: one or more BCD fields out of range for "backward_I_offset"
++ WARN: mpeg user scan data: one or more BCD fields out of range for "next_I_offset"
These lines keep on repeating in the log till VCD imager thinks it has warned me enough. Also on the end of each line is a time code mentioning of the fault.
I am converting with XMpeg using the CCE codec.
How do I solve this ? (Though after burning the disc plays fine, I want it to be perfect).
Greetz
Mars-L
