Does anybody know what FREE SOFTWARE that can convert any type of auido format to aac format?
I can't live without my computer.
Thanks for replying.Now I can convert to aac format but there's another problem.When I burn on a cd using nero(nero digital audio),the burning process is successful but when i play it on a cd player or on the pc,the songs arent there except for a 36-seconds silence!Im trying to burn songs as aac bcuz nero says that more songs can be burned than any normal audio cd if the songs are in aac format.So,does anybody know how to burn aac auido files so that the cd can be played on any cd player?
I can't live without my computer. -
You can't. CD audio is a standard (Redbook) and you have to meet that standard. AAC is an audio compression that is not compatible with standard CD audio playback. Yes, it allows you to put more audio on a CD. So does MP3. However these are burned as data discs, not CD audio discs. The player must be able to read data discs, recognise that the content is AAC3, and decode it for playback. Many players can do this for MP3, but I don't know of any that can do it for AAC.
Read my blog here.
Some newer car stereos support AAC.
I recommend converting to MP3@192kbps because MP3 is widely supported,you can get ~120 songs on a CD.
BTW:you have to use Nero Showtime to listen to Nero AAC.
Covert a .mp4 movie's audio alone to mp3 without changing the video quality
By ckarvnd in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 12:02 -
MeGUI, problem to encode audio from all AAC format(tape fast-forward sound)
By squall0833 in forum AudioReplies: 9Last Post: 13th Jun 2010, 15:54 -
I want to conver a file to FLV format. with audio aac and video as mpeg4/h2
By krishsamy in forum Video ConversionReplies: 1Last Post: 11th Nov 2009, 03:45 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19 -
aac: Unkown Format? when muxing
By OrangeJelleh in forum ffmpegX general discussionReplies: 6Last Post: 14th Sep 2007, 13:09
