I need help, I'd like to create a DVD with scenes from different movies. I want to make a collage with scenes from a whole bunch of movies a like, but I just want to extract these scenes and put them all together in a DVD, so when I play it back, it will be just one scene after the other, like a movie made out of many different movies.
How do I do this?.
Thanks,
Aplaza.
Go through each movie in turn and cut out the scene you want using DVDShrink in reauthor mode and use the Start/Stop feature (you can select starting and ending points within the movie). Once you have all the scenes cut out (and saved to different folders), follow the instructions here:
http://members.dodo.com.au/~jimmalenko/test.htm
This will create a DVD with each scene as a new chapter, and it should just play from go to woe.If in doubt, Google it. -
Drag the main movie to the left-hand pane, as you would for a movie only re-authoring. Once there, right-click on it and select "Set Start and End Points" (or similar - it's been a while). When you back up the disc, only the section between these points will be kept. If you want multiple scenes form that same movie, repeat as many times a necessary.
Read my blog here.
How to Add Deleted Scenes & make it complete version?
By skorpinok in forum Video ConversionReplies: 2Last Post: 1st Jan 2012, 06:29 -
How can I take the clips from movies/DVD's and make them into videos ?
By jackbruce in forum EditingReplies: 5Last Post: 13th Nov 2011, 23:08 -
How to make DVD movies in high quality
By bell in forum Authoring (DVD)Replies: 11Last Post: 2nd Nov 2009, 08:42 -
How to make DVD recorder disk playable on TV with all scenes intact?
By Stabes in forum Newbie / General discussionsReplies: 1Last Post: 29th Dec 2007, 14:02 -
scenes missing from store-bought movies
By johnsees in forum Newbie / General discussionsReplies: 11Last Post: 19th Oct 2007, 15:53
