hi. i burn my vcds with nero. it all work well but i cant get the end of the movie. it wont burn the last 3\4\5 min.
can i fix it?
I think you're using the latest version of Nero (5.5.7.2) ???
Throw it away and go back to 5.5.6.4 (or 5.5.6.9 if you can find it).
Had the same problem, costed me 10 discs. And going back solved the problem. (Seems to be a bug with some Recorder brands)
Greetz
Mars-LThere R 3 sides on every story;
Yours, Mine and the truth
Copy to DVD suddenly wont burn DL
By Yorel in forum DVD RippingReplies: 4Last Post: 25th Apr 2010, 21:42 -
ConvertXtoDVD wont burn movie
By hewhoeatsall in forum Authoring (DVD)Replies: 1Last Post: 14th Dec 2008, 19:58 -
Burn DVD using DVDFab end result one file in iTunes?
By Kramer620 in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 21:26 -
My HP DVD Writer 840x Wont Burn !?
By ticotaz in forum DVD & Blu-ray WritersReplies: 3Last Post: 16th Jan 2008, 05:23 -
wont burn dual layer
By mark o in forum Newbie / General discussionsReplies: 7Last Post: 26th Jun 2007, 20:04
