I loaded a movie into Elements and added brightness, as the original was too dark. It all worked a treat until I saved the movie back to hard drive. It came back as a 19 GIG file!
What did I do wrong?
It sounds like you've saved to a different format, and one that creates bigger files.
As an example DV AVI is about 13.5Gb per hour. Saving to uncompressed AVI is about 5 times that.
I use Premiere (not Elements) and the default for that is DV AVI.
Ideally, it'd be handy to know what the original file format was and how lung it runs for. Use GSpot to tell you both.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Sounds like my problem.
Thanks for the help.
The Cockney Canuck.
(Come on you Spurs!) -
No problem. Feel free to come back with any more questions.Originally Posted by didikai
Nah, nah, nah... "Come on you irons!!!"Originally Posted by didikai
Carpe diem.
The original file was in DivX 673 MB
Can I save it back as DivX after adding brightness?
btw. I just saw on the BBC news that The Hammers have just paid 2 million pounds for 10 spectators from Tottenham.
I'm not sure if Premiere - Elements or otherwise - picks up all installed codecs. You clearly have the Divx codec installed coz you can play the file (I assume). If you can't select Divx during "Export As" then consider ditching Premiere Elements and try giving VirtualDub (free) a go.Originally Posted by didikai
* Take a copy of the original file.
* Open VirtualDub. Maximise it.
* Click: File -> Open video file
* Right click on left video window and choose 66%. This is the original input video.
* Repeat for right video window - this is what the resultant output will be after changes.
* Click: Video -> Full Processing Mode
* Click: Video -> Filters -> Add -> [select] brightness / contrast -> OK
* Configure brightness roughly
* Click: The "Play Output" button = it's the third from the left in the bottom left corner. The universal "Play" symbol (arrow pointing right) with the letter "O" too.
* Refine brightness setting.
* Click: File -> Save As. Give it a different file name.
Job done!
Carpe diem.
O.K.
Brightness fixed as instucted in Virtualdub. But I get choppy sound, and I think the output file is still huge. -
Using GSpot again, get details of the audio. I would suspect that it's VBR MP3 - If so, try the same process but with VirtualDubMod as that handles VBR better.Originally Posted by didikai
Also, see below for an important step I missed...
D'Oh! I forgot to mention that VirtualDub (and its derivatives) output to uncompressed AVI by default. At some point prior to saving, click: Video -> Compression and select Divx. After setting "Full Compression Mode" would be good.Originally Posted by didikai
Sorry.
Carpe diem.
Sound Miss Match on Premier Elements
By NP11073 in forum AudioReplies: 0Last Post: 18th Jan 2009, 03:27 -
Problems with Adobe Premier Elements
By jeffprice74 in forum EditingReplies: 4Last Post: 21st Jun 2008, 11:24 -
Adobe Premier Elements 4
By Jedi5 in forum Newbie / General discussionsReplies: 0Last Post: 8th May 2008, 23:01 -
Premier Elements 4 and codecs ?
By holeepassion in forum EditingReplies: 0Last Post: 1st Feb 2008, 04:08 -
Premier Elements 3 and HDV
By AvalonMan in forum EditingReplies: 0Last Post: 17th Jun 2007, 07:19
